Question about Refrigerators
Norcold n611lt won't work on ac or gas
SOURCE: My norcold N841 will not cool on AC or Gas it has
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Posted on Sep 28, 2009
  • 332 Answers
SOURCE: My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
tunde007
  • 2382 Answers
SOURCE: Model 12110 IM Norcold-not cooling
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Posted on Apr 13, 2011
  • 5370 Answers
SOURCE: norcold 2 way refrigerator. 5 amp glass fuse
A shorted heater element will cause the 5 Amp fuse to blow.This is most common reason for this fuse to blow. ---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/5-amp-glass-fuse-keeps-blowing-on.html --------- This should help.Thanks.Helpmech.
Posted on Jun 05, 2011
  • 230 Answers
SOURCE: We can't get our Dometic
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Posted on Jun 27, 2011
I have a Winni Minni with Norcold refrigerator 682. I have change board and element,but its not working on electric only on gas, prpblems ?? I live in Norway.
Sounds like your selector knob may net be making proper contact with electricity. You have changed everything else. You could check power available with a multimeter to your element. If power not available to your element, back trace to source and check for burned wires or breaks in wiring.
Hope this helps!
Apr 18, 2016 | Refrigerators
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold 3163 Fridge
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
May 08, 2013 | Refrigerators
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
I have a Norcold 323 Refrigerator in a camper that will not cool when operating on AC but does work on gas, ( I cant test the DC as I dont have a 12 volt power sorce). After running in on gas for a while...
the unit runs on gas(LPG) so the unit is operational
by ac I take it you mean mains power and by dc you mean 12 volts it being a 3 way cooler
you cannot "jump start" a gas system so I am a bit lost with that statement
check the heating element in the unit for continuity as both the mains and 12 volt power only heat and element that boils of the coolant liquid in the system the same as the lpg flame does
it could be a relay problem for the electrical part
May 26, 2017 | Thetford Norcold N323 1.7-cu ft 3-way...
I have a Norcold n300 3 way it works on 110 but
try blowing through the gas orifice with compressed air only.
Jul 08, 2010 | Thetford Norcold DE0051 Refrigerator
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
