Question about Health & Beauty
Palm held hair trimmer
I have a Vidal Sassoon palm held hair trimmer.Unfortunately I have lost the adapter to plug the machine into, and therefore require an adapter (Model type EHC118PS.) Thanks Ken
4 Suggested Answers
  • 13 Answers
SOURCE: Replacement Blades
I dont believe you can get replacement heads for non-professional clippers. If you are going to invest in a new pair you could go to Sally's Beauty Supply and purchase a pair that you could always get a replacement head for.
If you dont want to invest in a new pair you could bring that pair in there and see if any of the replacement heads they have may fit. There is usually eather 2 or 4 screws that will go in there. You could find one that looks the same and it may just work! Good Luck!
Posted on Jan 09, 2009
  • 10406 Answers
SOURCE: Could you please tell me where i can purchase
Look in the "Yellow Pages" of your local telephone directory for a "Shaver Shop".
Posted on Mar 03, 2010
  • 7 Answers
SOURCE: Thanks! I have lost
You could try but then you'd have to install the blade yourself, risk breaking all the little itty ***** parts of the motor in there. In the end it's up to you if you want to go through the hassle.
Sorry, hope this helps though.
-Jord
Posted on Feb 28, 2011
How to disassemble Vidal Sassoon 1875 W (Blue) hair dryer?
hi
If the model is like this one you can use a paintbrush and with the hairdryer unplugged you can wipe the net full of dust. Then blow with air compressor if very dirty.
Plug it and enjoy
Feb 19, 2015 | Helen Of Troy VS783N3 - Vidal Sassoon...
How can i find a Charger for a vscl900 Trimmer
If you haven't lost the original and you think it burned out check it with a volt meter you may find the trimmer is no longer taking a charge. If there is no voltage coming out of the charger then I would try Ebay or the manufacture. Now the next thing you can do is make one out of an old cellphone charger or other a/c to d/c adapter. (If I have 10 of them hanging around the house I have 50 and have done this many times) Just check the voltage output including milliamps get as close as possible to the specs. (specs are always listed somewhere on all adapters). Cut off the the plugs from both chargers about a foot away from the plug. Strip all 4 wires on the old trimmer adapter it should tell you which which is the plus side and what is the negative of the plug. just twist the wires together and with a volt meter it should give you a positive reading. Now you not only recycled but you were only out a little time and no money.
Jul 14, 2014 | Vidal Sassoon VSCL867 Hair Trimmer
Vidal sassoon vs505 disassemble
There is one Philips head screw near the top of the handle and there are four more behind the rubber on the handle grip. The rubber on the handle grip is attached to a curved plastic plate that has four clips that hold it to the handle, you have to pop the plate with the handgrip rubber off the handle to access the four screws.
Mar 23, 2014 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
Is it universal volt
It is not listed as such. You should not plug a 120VAC unit into 240VAC.
Nov 22, 2013 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
My son screams that the clippers are pulling his hair, this started after a friend of mine took them apart to clean them
Pay a hair stylist to clean your hair clipper dont do it yourself . Throw away this one and buy another one .
Aug 13, 2011 | Vidal Sassoon 21PC Hair Clipper Set Hair...
How to dissassemble Vidal sassoon VSCL816. (e.g. scissors area). two phillips scresw unscrewed, but two shells of housing cannot be separated completely. Hint needed for taking away scissors. Scissors got...
I have a Vidal Sassoon Max hair clipper, and I suspect the construction of it is similar to yours. To take the two halves of the body shell apart you need to remove the blade assembly. Try this:
After removing the two visible screws, place your thumbs at each end of the cutting blades and push upwards.
The blade assembly should unclip, revealing two more screws underneath. Remove these, and the two halves of the body shell should come apart.
Graham
Apr 10, 2011 | Vidal Sassoon VSCL816 Beard Trimmer
Replacement blade
GO ON LINE YOU SHOULD BE ABLE TO ORDER THEM FROM VIDAL SASSOON.
Mar 15, 2009 | Vidal Sassoon VSCL900T2 Hair Trimmer
Replacement Blades
Mar 25, 2008 | Vidal Sassoon VSCL867 Hair Trimmer
Health & Beauty Logo
42 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
