Question about Plumbing
Terrazzo floors repair cracks - Plumbing
How to tile a floor
Billy, Click on and read the links provided to learn how to tile a floor.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://novafloor.us/installation-guides
http://novafloor.us/wp-content/uploads/2014/09/Installation-Guidelines-for-Direct-Glue-Tile_Grout-v2-10_2015.pdf
http://novalis-intl.us/wp-content/uploads/2012/10/LUXURY-VINYL-TILE-INSTALLATION-GUIDE.pdf
May 15, 2016 | Novalis Bella Tiles 18 x 18 Bella Napoli...
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
Do I need a lot of tools to cut tiles?
You don't really need too many tools to cut tiles, mainly just a tile cutter, tile nipper, sharpening stone and pencil.
Nov 17, 2013 | Cutter Tools
Repair concrete floor, large cracks in flooring
install backer rod into cracks that are more than an 1/8 and use concrete sealer (in the caulking section of your local hardware store). The backer rod is used to reduce the amount of sealer you have to use to bridge the larger gaps in the cracks.
Nov 05, 2013 | Mozilla Firefox
Boat floor and body repairs
none rubber backed carpet , clean off the floor and spray or a can of glue and coat both after shaping ! cracks in gel coat need grinding out and filling with gel coat repair filler then paint with 2 pack marine under coat paint then top coat !
Jul 29, 2013 | Boating
Older shower stall with crack in floor
yes go aout zone and pick up a fibber glass repair kit or some 30 min epoxy
either one of thesr will fix it
the floor will will have too be sanded before appling and after its set up
Mar 29, 2009 | NRS Jones Stephens Corp. S01-050 Shower...
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
What Kind of Sinks?
Sinks are made of many different materials. These include Stainless steel, Enamel over steel or cast iron, Ceramic, Plastic, Soapstone, Concrete, Terrazzo, Totianota, Wood, Stone, Copper and Glass.
Aug 27, 2008 | Jcp Home Collection Marble-Top Vanity w/...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
