Question about Daniel Cota DrawCast - Drawing/painting/sketching
Karactos I can't see any of the comments in my any of my drawings why is that? and how do I fix it?
When I turn on my heater on 2001 mazda tribute it makes the car want to turn off but as soon as I turn off heater the car regains its power? What do I do to fix it? What can my problem be
I can think of 2 scenarios that might explain that - either your alternator isn't putting out and your blower draws enough power that the ignition begins to fail, or may be the heater/blower circuit has a short that is drawing power from the ignition. Post any new details or findings via comment to this original question please! Good luck.
Jan 05, 2015 | Cars & Trucks
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
My front Master Cylinder doesn't work. I've already tried bleeding the brakes and there's no pressure even drawing the fluid through the line. Any ideas on how to fix this?
I'm going thru the same thing...I blew air in the line with pressure and the caliper worked...open heart surgery master cylinder and caliper and no signs of wear and tear...to me its like if the master cylinder doesn't have enough pressure to push the brake fluid......my conclusion ..faulty master cylinder...
Apr 04, 2012 | 2000 Yamaha V Star Classic
Fix soap dispenser on xtreme dw-1840 bv pressure washer
it will only draw soap when your using the large fitting they don't draw with the high pressure nozzles
Mar 22, 2012 | Garden
Model WPRB9220C draws cold water when it's supposed to draw hot.
Your hot water inlet solenoid has failed and needs replacing.
Mar 11, 2012 | GE WPRB9220C Top Load Washer
Wiring colored wires to harnest for a stock stereo in a 95 chevy blazer
Hello! Justine this is Guru....Saailer...I Have the circuit drawing your asking for but I'll need your e-mail to send it ...Your e-mail will be kept private...Send a comment to; saailer@ec.rr.com and I'll send a PDF back to you...............guru.............saailer
Sep 29, 2011 | Jl Audio Stealthbox Single 10" Chevy...
Poor wiring in newly acquired truck need a wiring diagram for a 1984 ford f150 4.9 liter charging system i have burnt wire at the voltage regulator and would like to know the wiring system in order to do...
Hello! We do not have the capability of including that large of a schematic in our comment...
I'm giving you my e-mail....Send a quick note and I'll send you the drawing...This way your e-mail will be kept private...
saailer@ec.rr.com Guru...................saailer
Sep 27, 2011 | Cars & Trucks
What part is the cell in the pump and how do i clean that?
Take a look at the pics included and instructions. This should guide you...
Find the electrolytic cell in the drawing.. The long tube with the big black plug... Here's the instructions for the cleaning process.. Good luck and hope I helped.. If the information is useful, please rate or add comment...
Jul 30, 2011 | Intex Automatic Salt Water System for ...
I have a Midland 1001Z (in use about a year) that draws power when it is off. This happened when the unit was not in use and drained the car's battery. On the bench I checked and there's about 500...
it shouldn't be drawing. if there was a real problem with the radio it shouldn't even turn o..,off.clicked is switch power the juice.pulling actually is it if see actually to meter clamp a need would you resistance will have nothing to do with power drawing. you will alwayssee zme sort of resistance. on. I have left a cb on in my vehicle for over a week and it did not kill the battery. I think what ever drained your battery has little or nothing to do with your b radio. ohms is resistance. it is not a measurement of current. this does not tell our it is drawing anything
Jul 06, 2011 | Midland 1001Z 40-Channels Base CB Radio
HD72 - LAMP GOES OUT IN 30 SECONDS
The projector is sensing the amp draw from the bulb and shutting down due to out of spec draw...replace the bulb.
Oct 21, 2008 | Optoma HD72 Multimedia Projector
Daniel Cota DrawCast - Drawing/painting/sketching Logo
69 people viewed this question
Top Daniel Cota Apps Experts
Erin Wood
Erin Wood
Are you a Daniel Cota App Expert? Answer questions, earn points and help others
