Question about Sokkia Sdr33 Data Collector For Total Station
SDR 33 Data Collector Does Not Upload
On the SDR 33 Data collector we can download surveys into AutoCad Civil 3D 2009, but when we try to upload points from AutoCad to the SDR 33, it does not allow us to do so. It brings up an error message. What is the solution to the problem? We were having trouble downloading from the data collector to AutoCad, but we got the problem resolved with that.
Autocad 2008 version serial key
AutoCAD is not a free product.
You can download AutoCAD 2013 trial from this WEB site.
http://usa.autodesk.com/autocad/trial/
Feb 23, 2013 | Autodesk AutoCAD Civil 3D 2008 Full...
Someone is calling my phone and sending random messages i have the number and want to know who it is...the number is 07592893171
Looks like a couple of people have been posting about this phone number calling them. It might be a debt collector or a survey collector. I wouldn't worry about it!
Thanks!
Apr 05, 2011 | Lands Phones
Can GM45 chipset which provides upto 384mb shared grahics memory support all civil engineering softwares lik 3d autocad etc
yes, my dear friend.
GM45 chipset got an onboard 4500MHD graphic card
and can process 3d works (like work with autocad and maya etc) with a good pace.
Jan 27, 2011 | Computers & Internet
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
Upload video data to computer.
how do you upload ,by using sd card or usb port?
Dec 26, 2009 | Panasonic SDR-S26 Flash Media Camcorder
32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
Sokkia Sdr33 Data Collector For Total Station Logo
50 people viewed this question
Top Sokkia Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Sokkia Measuring Tool and Sensor Expert? Answer questions, earn points and help others
