Question about Karcher K2.26 Electric Power Washer
Karcher t300 patio cleaner no spinning
I've got water coming out of nozzles,but it is no longer spinning them around
4 Suggested Answers
  • 251 Answers
SOURCE: Dear sir/madam I bought a kArcher model K3.97
Peter , sorry to say but there is no replacement parts for that lance , you just replace the entire thing
its called a Dirtblaster lance
Posted on Nov 08, 2009
agent91
  • 2100 Answers
SOURCE: how do i use the patio & deck cleaner
The nozzle on the end of the wand either twists or pulls out to get you into soap mode, the liquid you have in the tank come out real slow, it does not come out with the high speed nozzle. The idea is to soak the job with detergent, then blast it off with the high pressure water. Hope this helps.
Posted on Mar 23, 2010
SOURCE: Karcher dirtblaster leaking at the end
If it's leaking it obviously has a bad seal or is broken. I would try to disassemble and see if it has a seal or not. Sounds like you could have a bad "O" Ring or some other type of seal leaking but I'd bet on an "0" Ring damaged or wore out. Dissemble it and see what is sealing it and proceed accordingly.
Gillight
Posted on Jun 26, 2012
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
Karcher K4
think it must be faulty power
Jun 10, 2008 | Karcher 2500 PSI Pressure Washer
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
Karcher lance fitting
if they are the plastic version, replace them as they tend to "expand" as they age and won't fit properly.
Jul 08, 2014 | Garden
Water coming in dishes not getting cleaned enough.possibly not coming out of the sprayer and spin blade
Look inside the spin blade and see if there is food or paper inside of the spin blade exit holes blocking it from spraying and spinning. Also if the spin blade is not aligned with nozzle which sprays water into the blade it will not work. I have had both happen several times. Sometimes dishes or pans pushing against the spray nozzle will also miss align the spray jet so the water does not get into the spin blade. I have also had the spin blade be completely worn and would not spin creating the same problem you've had so I had to replace it. Hope this helps.
Oct 04, 2013 | Maytag Dishwasher
Karcher paatio cleaner attachment cleaning in suiggly lines
Squiggly lines are sign of nozzles being partially clogged. Try using a needle to clear nozzles. You will need to remove the nozzles to do this. When re-installing the nozzles make sure they are in line with the pressure bar.
Mar 13, 2013 | Karcher KE302007A Classic Series Pressure...
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
HOW DO I DRAIN THE WATER FROM MY HP WASHER FOR WINTER
What I've always done is just disconnect the water hose then start the washer and pull the trigger till no more water comes out. You don't want to run it very long at all after there's no more water though, you can quickly overheat the pump if it is ran without a water supply for too long. I've been doing this for the past 3 years with one of my washers and haven't had any problems with the pump.
Oct 05, 2012 | Powerboss 020309 3000 psi 2.5...
Karcher K2.26 Electric Power Washer Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
