Question about Vehicle Parts & Accessories
Can the starter make the car shut down - Vehicle Parts & Accessories
  • Vehicle Part... Master
  • 3,799 Answers
That would depend on the car and the security system. So, Yes it can.
Posted on Jul 16, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Have 2009 impala ltz shuts down going down road pull over have power but starter won't engage
The starter is computer controlled by way of a relay ! When you turn the key to the start position a low voltage signal is send to the BCM - body control module , the BCM then sends a message over the GMLAN serial data network to the PCM for starter engagement , The PCM energizes the starter relay sending B+ voltage to the starter solenoid ,if there are no anti-theft system problems. The codes you have listed are emission related codes !
DTC P0455: Evaporative Emission (EVAP) System Large Leak
You must mean P0442 , because there isn't a code P0422 .
DTC P0442: Evaporative Emissions (EVAP) System Small Leak Detected
None of these would cause vehicle to shut down > Your best bet would be to take your vehicle to qualified repair shop an have diagnostics run on it .
Sep 23, 2016 | 2009 Chevrolet Impala
Car shuts down for no reason while driving is there a solution?
Solenoid holding the bendix drive in mesh have starter checked out
Feb 22, 2015 | 2006 Buick Lucerne
Ford tractor
How old is the fuel in the tractor? is it petrol or diesel powered?
Apr 14, 2014 | Cars & Trucks
Engine shut down while driving
stalls
are complex.
can be many things.
testing solves all riddles.
got tools, got hand gauges and meters?
stalls with foot in it.
or only at traffic lights?
that be the first question,
Sep 11, 2013 | BMW 750 Cars & Trucks
I have a 97 expedition and it will start with no problem but when i drive and the suv and it gets to the normal tempeture and i turn the car off it will not start i have to wait for 20 min or more until...
I would say your starter is faulty. Since the vehicle runs fine, and doesn't start up after being shut off until it has cooled down, it sounds more like a starter that loses contact when it is hot. You could check the starter terminals for 12 volts using a multimeter when the key is turned to Start the engine after warming up the engine and shutting it off. If 12 volts are present, replace the starter. If 12 volts are not present, check the Starter relay.
Apr 15, 2011 | 2001 Ford Expedition
Hyundai sonata 2000 starter The starter will not shut down even when the engine is shut-off and the key is removed from ignition
Your starter is grounding out.Check the wires going to the starter.Unplug your battery to turn it off and before you check wires.
Feb 07, 2010 | 2000 Hyundai Sonata
Our 2003 caravan just stopped starting,we have owned this van for 4 mon no problems, only 70000 mls, all of the sudden it won't start, changed out auto safety shut down relay switch, ignition switch still...
Check the starter selenoid, check for corrosion on batt, terminals and inside the cables, tap the starter with a metalic object and try to start the car, if it starts change the starter.
Jul 10, 2009 | 2003 Dodge Caravan
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
