Daikin error c1
Indoor unite model number FBQ71DV1 error came c1 I need wate is this
farfield
  • 462 Answers
SOURCE: will you tell me the electrical diagram of 12
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
  • 306 Answers
SOURCE: need recommended sub-cooling and superheat for
Superheat should be 8 to 12 degree's. Sub cooling around 18-22. I like to use superheat that way I know the coil is doing all it can do.
Posted on Jun 16, 2009
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
SOURCE: My Daikin AC is showing
p.c.b feed bak signals is failed.probably,,temperature sensor or fan motor signal.
Posted on Jun 12, 2011
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
Jul 30, 2017 | Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
How to solve u4 alarm in daikin inverter 24000btu unit
Feb 08, 2011 | Heating & Cooling
May 28, 2010 | Cfm Daikin R410a Split System Air...
Will you tell me the electrical diagram of 12 floor standing vrv daikin?the model of indoor units are fxlg63mave and the outdoor units are rxyq12p7ylk rxyq10p7ylk rxyq8p7ylk
Mar 02, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
