Question about Maytag Legacy Top Load Washer
Maytag Legacy We have determined that a nail or screw is stopping the spinner from spinning! How do I take the drum and drum liner apart?
  • 3 Answers
The drum liner comes apart by removing the top, the top ring and the agitator the inner drum will then pull out . chances are what you are hearing is the bearings which if you read here on other questions is a defect on this machine. mine were replaced 3 months ago and they have gone again. tech told me the seal on this machine is defective and they have repeated problems.
Posted on Jan 11, 2008
  • 291 Answers
Need a special tool to remove the lock nut on the spin tub
Posted on Sep 02, 2007
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
Have a UC code. Washer starts than stops during cycles when the drum is moving. also hear a clicking sound Tx, Bob
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune washer always has water in the drum after wash is done? Any ideas? I can hear lots of water left in the washer when I spin the drum manually and of course it has a moldy smell having water...
The liquid is a saline solution which is hermetically sealed in the front balance ring on the spinner. It is there to reduce vibration and acts like a gyroscope when the spinner revolves. Good sound to hear when you spin the basket. The smell can be gotten rid of by using a washing machine cleaner like tide.
Dec 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer stopped working during the wash cycle. it made a clicking noise when it happened.. I pulled off the belt it is still in one piece . when i put the maching in spin with the belt off the...
If you turn the transmission pulley one way it will agitate the other it will get hard raise up to release the brake and then turn the transmission and the inner drum. If you cannot turn the drum then I would check to see if a nail has gone through one of the holes in the bottom of the drum or a piece of clothing has jammed between the top of the drum and the top cap of the outer tub.
Nov 01, 2010 | Maytag Performa PAV3200
Maytag model dwu9200aax pieces of plastic and cloth clog some of the rinse holes on the spinning rinse to take apart rinse arm to clean it?
The top spinner part can simply be pulled off by grasping it near its hub and pulling downward. Push it back on and push in the locking clip in the center. The bottom spinner can be removed, First unscrew the center column. Hold the spinner with one hand, turn the base of the center column counter clockwise. Then lift column off. Then the spinner should lift off of the keyed white plastic base. Underneath it, on the neck off of which you lifted it, are two plastic washers that form a seal (supposedly). Good to clean these to make spinner rotate freely, but be careful not to break them taking them off. If you want to go farther in, there is the point of a strange shaped plastic nut sticking up into the base of the column. If you remove this, and the 6 torx screws holding the strainer cap, you can get it all out to clean it up (I had bits of plastic bag in the slots of a 4-armed thing that apparently sprays the filter screen), and scrub the washer in the bottom. Remarkably yucky down there in a 10 year old installation...
Nov 11, 2009 | Maytag MDB6650A Built-in Dishwasher
During the spin cycle, my maytag washer makes a rather loud clicking sound and stops spinning. It immediatly starts back and the process repeats every time the machine spins at top speed.
The problem most likely is something stuck in the water port of the drain pump.
The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump.
Thanks for contacting
Sep 30, 2009 | Maytag MAV2755AWW Dependable Clean Top...
I have a maytag legacy and i need to know about
Can you please expand just a bit more, did you get the belt back on but cant determine the serpitine pattern or cant get it around the drum.
Aug 03, 2009 | Maytag PYE2300AY Electric Dryer
Maytag washer top load
good the washer balanced? That can make the spin cycle work ineffectively.
Feb 15, 2008 | Washing Machines
My washer will not spin off the water
Check the drain hose and make sure it is not plugged or kinked. Check as well that pumps spins. Good luck
Aug 19, 2007 | Maytag Legacy Top Load Washer
Washing Machines Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
