Question about Refrigerators
Bypass defrost timer
Once i have bypassed the defrost will it cause a problem after a while? For instance, will the fridge freezer begin to stop working properly?
  • Refrigerators Master
  • 4,655 Answers
Just turn the defrost tmer clockwise to cause defrost or run conditions. If you bypass the defrost timer you will have problems like shorting of wiring or loss of the timed defrost. Why not replace the defrost timer if you know it is defective? What is the model number of your refrigerator? Thanks Sea Breeze
Posted on Jul 16, 2013
SOURCE: warm fridge
If this Amana has digital display at top in fridge more than likely the Jazzboard (control board) has failed. Check for votage at fan if you don't get any or some times if you do the Jazzboard can still have issues controling the evap.fan. I've found the Jazz board to go bad some times. Hit me back let me know. Jazz board is in the control box were the digital numbers light up.
Posted on Jan 27, 2008
aborcass
  • 2651 Answers
SOURCE: Freezer stops working for no reason
sounds like a defrost issue, see if theres a wire diagram id ck your heater/defrost circuit
Posted on Feb 24, 2008
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
  • 358 Answers
SOURCE: Cant find defrost swicth on NEC fridge freezer
The defrost timer should be inside the refrigerator where the cold control is.
Posted on Apr 23, 2009
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Dec 01, 2012 | Refrigerators
My freezer (upper) works but my fridge (lower) doesn't. There's nothing clogging the vent. What could be the problem? Thank u!
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and are not torn or ripped. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the f
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some are behind the cold control cover. Once you locate the defrost timer, slowly turn the screw likeknob in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater (s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can continuity test the defrost heater for continuity or test for 120 volts to the heater(s). If you have no power to the defrost heater (s) you can also bypass the defrost thermostat to see if the defrost heater will come on, jumper the wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater (s) and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
bobicehouse_88.jpg Defrost timer
bobicehouse_89.jpg Defrost thermostat
bobicehouse_90.jpg Defrost heater
Sep 11, 2011 | Sharp Refrigerators
Not defrosting
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on, replacethe defrost timer and defrost thermostat. If the heater itself is bad, replaceit. Thanks and hope helpful.
Feb 14, 2011 | Electrolux ER7926B Bottom Freezer...
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The freezer retains frost and obstructes the fan.
Defrost cycling is poor.
Locating the defrost timer hiddenbehind the back bottom corners of the fridge at the bottom, in some units it's located in the ceiling of the fresh food section,and some behind the cold control cover. Once you locate the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer with astraight screwdriver until the fridge shuts off. You are now in defrost. If thedefrost heater(s) comes on now, replace the defrost timer and defrostthermostat. If the heater(s) does not come on, you can ohm test the defrostheater for continuity or volt test for 120 volts to the heater(s). If you haveno power to the defrost heater(s) you can also bypass the defrost thermostat tosee if the defrost heater will come on, join the 2 wires together to bypass thedefrost thermostat. If the heater now comes on, replace the defrost timer anddefrost thermostat. If the heater itself is bad, defrost the fridge with a hairdryer, replace the defrost heater* and defrost thermostat. If the defrost timerseems "hot" to the touch or is noisy ( like a ticking or screechingnoise )...replace it. Once defrost cycling is cleared, you will get better cooling in fridge compartment also. Thanks.
Jan 31, 2011 | Whirlpool Refrigerators
Freezer is freezing, but fridge temp ranges between 40 and 50 degrees, problem?
Greetings,
usually this is a defrost problem...See if there is ice building up on freezer back wall and if so, you will find the evaporator froze over. I would first make sure you see or hear the freezer fan motor coming on. A evap fan not coming on will cause a no cool problem in fresh food section.
If there is ice on the freezer coil. It needs to be defrosted and then we can find the problem. Once its defrosted..it will work good as new until it freezes over again..The most likely problem is defrost thermostat or heater or timer or electric defrost board...you need to know how to use a meter to check these. The defrost thermostat can be bypassed to check it. use your meter to check the heater..if good, and you bypassed the thermostat and nothing happened..Its most likely the defrost timer or board. If a manual timer..you can advance it to defrost and see if it comes on.
if its an electronic defrost board, sometimes you can get them into a defrost by pushing the light switch in 5 times within 10 seconds..there may be a tech sheet on the refrigerator showing this
please let me know if you need more help....Bruce
Nov 25, 2010 | Whirlpool ET8RHMXKQ Top Freezer...
The freezer and frig both stopped cooling we turned them both off but nothing happened
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help in solving the problem......
Oct 25, 2010 | Whirlpool Refrigerators
Freezer is not freezing and refrigerator is not cold
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
Hope this helpout.......
Aug 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
My refrigerator is not working properly. The freezer is functioning correctly although the cooler is not cooling, my food is getting spoiled.
Step 4 – Volt Test
Aug 13, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
French doors with freezer at bottom. Not cooling properly, have on highest number to cool. Freezer seems to be fine
Step 4 – Volt Test
Aug 13, 2010 | Whirlpool Refrigerators
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
