Question about Water Heaters
Pressure relief valve specification for Rheem 21V50 2 water heater
  • 686 Answers
SOURCE: Relief valve constantly releasing water.
lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
Posted on Jan 08, 2009
garypetterss
  • 15 Answers
SOURCE: pressure relief valve
The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
Posted on Apr 11, 2010
  • 494 Answers
SOURCE: MY GE PRESSURE RELIEF VALVE HAS JUST STARTED
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Douglas
Posted on Jun 14, 2010
motor1258
  • 6674 Answers
SOURCE: just purchaced a 99 jamboree with an atwood G6a-8e
It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
Posted on Nov 17, 2010
SOURCE: how to replace a faulty pressure relief valve on
Open following link to see step-by-step.
BE CAREFUL, tank must be turned OFF and water COOL before removing TP valve.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Posted on Feb 15, 2011
Water heater relief valve tightened up over wiring???
You can turn off water and add a few layers of teflon tape to snug it up a bit. You should also run a pipe down to 9" from the floor. that will remove any danger to the wires
Jun 09, 2014 | Rheem Water Heater Pressure Relief Valve
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Overflow high pressure valve leaking
Replace the relief valve & add an expansion tank.
Apr 06, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem Marathon Water Heater leak at pressure relief valve
Unless you are getting more than 150 PSI, you should just replace the valve. It has dirt in it.
Dec 27, 2012 | Rheem MSR50245 Marathon Electric Water...
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Leaking pressure valve when showering or running dishwasher
That happens sometimes when the pressure relief valve goes bad...
Change the relief valve and you'll be good again...
heatman101
Feb 01, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Leak from the left top valve
This called a pressure relief valve, these are meant to blow off and relief pressure if it needs to. These valves do go bad and need to be replaced from time to time.
May 02, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
