Mafikizolo list songs - Audio Players & Recorders
6th gen. nano has shuffle issues. plays same song over and over
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
Feb 12, 2013 | Apple MC526LL/A iPod Nano 16GB - Silver
If i accidentally choose a song, can I go back to the song list, or quit a song in the middle of playing?
Yes.
During the song, all you have to do is press and hold the + button. After holding the + button, the song will end and you will go back to the song list.
Apr 04, 2010 | Konami Dance Dance Revolution Hottest...
Hi I have windows7 on my laptop. I am unable to remove songs from my Scandisk. Media player also should be latest. Can you guide me how to remove or add songs in my e260 .
By pressing and holding the Select button while listening tomusic, the player will automatically detect whether the current song isalready in the "Favorite List" and guide you to add/remove the songfrom the Favorite list.
STEP 1 - Enable "Advanced mode"
1. From the Main menu, select Settings > Advanced
2. Select On.
STEP 2 - Add song to the "Favorite List"
1. During music playback, press and hold the Select button.
NOTE: If the song is in not in the list, a confirmation message for adding the song to the list will be shown.
2. To add, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
STEP 3 - Remove a song from the "Favorite List"
1. During playback, press and hold the Select button.
NOTE: If the song is already in the list, a confirmation message for removing the song from the list will be shown.
2. To remove, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
Feb 26, 2010 | SanDisk Sansa e260 MP3 Player
I am trying to burn a cd on my Acer Aspire 5536-5255 using WMP and it isn't working?
In Windows Media Player, click Library and then, in the List pane, click <List Name> List, and then click Burn List, as shown in the following screen shot.
  1. If you need to clear the list before beginning, click Burn List, and then click Clear List.
  2. Drag a folder from the Contents pane or songs from the Details pane to the List pane to create a list of songs to burn.
  3. In the burn list, drag songs up or down to arrange them in the order you want them to appear on the CD.
  4. Insert a blank CD-R or CD-RW disc in the CD drive.
  5. In the List pane, verify that the songs you have selected to burn will all fit on the disc. If necessary, remove songs from the list by right-clicking a song and then clicking Remove from List, as shown in the following screen shot.
It is possible that a song will not fit even if the total time exactly matches the CD length, because the Player inserts two seconds between songs when burning. Click the Start Burn arrow and verify that Audio CD is selected, as shown in the following screen shot.
lick Start Burn.As the CD is burned, you can check its progress in the burn list. Burning a CD will take some time.Notes It is recommended that you do not try to perform any other actions while burning a CD. For example, playback may be affected if you try to play a music CD while burning a CD.
You cannot burn additional files to a CD after burning is completed. If you are using a CD-RW, you can erase the entire CD before using the Player to burn files to the CD again.
Nov 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Music Player not working properly
try refreshing,rescan your song list...
Sep 07, 2009 | LG Xenon GR500 Cell Phone
My nokia e51 only plays one song
Have create a track list containing all the songs? If you haven't done so, create a new tracklist in Tracks,
  1. Select New Track list
  2. Select memory location to save the List
  3. Name the Track List
  4. Then select the songs like like put in the list by Marking each song
If you want to add new songs in the list, you can edit the Track List and repeat pint 4 above.
Then you play the songs in the List randomly, etc.
Jul 31, 2009 | Nokia E51 Smartphone
Song Duplications
Do not syc with wmp. Drag and drop everything from windows explorer to the media folder on the sansa.........Format everything first ....Start over
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
"Unknown" listed in spots for songs in player's list of all songs
It's the id3 tag information that hasn't been filled out, most likely.   (id3? Hmmm)
Anyhow, depending on the operating system you use and the program you use for your music, it's easy to change.
If iTunes, just import the song into itunes, and "edit Info" and change all the song information. In Windows I believe you can do it in WMP, or by right-clicking the file.
Alot of the time a song just has the info in the filename, but mp3 players use the id3 tag to identify a song.
Dec 22, 2008 | SanDisk Sansa e260 MP3 Player
Songs listed in ABC order
you might be able to find "edit" under right click. lets you edit the file information.
Mar 15, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Music not on mp3
wot i suggest is yopu reformat your mp3 by using your computer removable disk formatter hope it helps you.
Aug 22, 2007 | iLO (2 GB) MP3 Player
18 people viewed this question
 Grubhead
Grubhead
