Question about Briggs & Stratton Garden
Self propelling cable seems to be broken
Self propelling mechanism ie.cable seems to have snapped
    Problem Solver:
  • 11 Answers
Seems to be or has broken.
Posted on Jul 16, 2013
  • 59 Answers
SOURCE: self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it tj_gunter@comcast.net
Posted on Jun 26, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
bulldogchief
  • 388 Answers
SOURCE: honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Posted on Sep 08, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
TB210 Drive Engage Cable. Can not remove Front Cover.
Hi Chip, I too have a model 12AGA26E011 which has suddenly stopped being self propelled. I'm looking into how to remove the top cover so I can get to the belt and drive mechanism to determine what is amiss. If i have any luck I will let you know. obviously others that have posted here are stating the obvious but not answering your question. If you happen upon the solution please provide an update. Thanks! Doug
Jul 13, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 6.75 self-propelled...This is for a friend of mine. She has a broken arm and her mower will not operate as it should. The self-propelled function is not working. She spoke with someone who...
The self propel lever is the bottom one, the top one is the running lever. Have her check the cable coming out of that one. var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 06, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Oct 01, 2009 | Garden
Honda harmony self propelled cable snapped at end
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self propel feature broke on Hoover Tempo Widepath
Sounds like the tie has loosened the belt off. You may have to check under neath the sole plate by removing screws and having a look. If the belt is broken it will have to be replaced. If its not broken check that it hasn't moved within the gear assembly of the self propel mechanism. Fit everything back together and it should work after that.
Feb 20, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Self-propelled Broken?
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Aug 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Garden Logo
37 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
