Question about Brother HL 5250DN Laser Printer
Paper gets stuck in printer
When I go to print something the paper goes about halfway through the printer and stops. I get about half a page printed. Sometimes, the paper actually goes all the way through but comes out folded. This is very frustrating as it wastes lots of paper and toner. Anyone have any ideas?
    Scholar:
  • 31 Answers
Hi, I work on these alot and see the problem quite frequently. It can usually be fixed by 1. either replacing the drum and toner which will eliminate alot of guess work, and if that doesn't fix it then 2 you have a bad fixing unit (AKA fuser). The folded paper makes me think that it's most likey a fuser problem but you can check by opening the rear door and looking for two rollers that are about as thick as two fingers and see if they roll during a test print. Sometimes the gear on the fuser gets broken and while the printer thinks that everything is working okay, it doesn't have a way of sensing the fuser actually rolling. Just as an FYI (and I know this isn't good news) but usually a fuser/fixing unit runs about the same price as the printer itself. So if your printer is on the older side you might want to consider a new one. Good luck.
Posted on Aug 28, 2007
6ya staff
SOURCE:
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
I was printing a 10-page job and the first page just got stuck halfway out of the printer. I tried pressing the reset buttons, tugging gently on the paper, nothing. I tried unplugging it and plugging it...
If the paper is halfway OUT of the printer, that means that the other half is stuck in the fuser.
Open the toner cartridge door and remove the toner. Leave the door open. This relieves tension on the rollers.
Grab the paper as close as you can to the back of the printer and pull the paper out carefully.
Put the toner back in and close the door. You may have to power cycle the printer.
Feb 02, 2011 | HP LaserJet 1012 Printer
Paper jam
Dear sir,
Open it from back side and chech the teflon paper, which is nearer to heater. May be damage of that paper also gives paper jam error.
Thanks
Sep 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper goes thru printer without printing
Look if you do the paper correctly in the printer and if you have enough colour to print then it should go^^
Sep 09, 2009 | Epson Stylus C120 Color Printer InkJet
Printing stops halfway through on Epson LQ300+
you use dpi 180X180 then print full page and speed fast
Jun 25, 2009 | Epson LQ 300+ Matrix Printer
Ghosting on HP2015 Printer
Hi gpeirce:
Ghosting is the result of a worn fuser assembly. Try to print a half page by printing a document and then try to open the top while the paper is going under the toner cartridge. You have to listen to the paper moving through the paper path.You will see that the paper has print on it but not the hole document. This will tell you if the toner cartridge is bad or the fuser assembly.
Hope this helps
May 30, 2009 | HP LaserJet P2015dn Printer
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Page prints half page then jams
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Dec 04, 2008 | Office Equipment & Supplies
HP psc 1315 all in one-printing cards
Make sure you check the settings in the print driver. Sounds like your paper size settings do not match the size of the paper that you are printing onto and you are actually getting a false jam because the machine is seeing a different size paper then you ahve in it.
Dec 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
Brother HL 5250DN Laser Printer Logo
309 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
