Question about Video Game Consoles & Games
Fruit machine I can hear the power surging through the machine and i can see the lights on the power supply are lit up and so are alot of green lights lit up but the actual lights and display wont light up and i cant play on it. it is a maygay sir win'a'lot.
    New Friend:
HI Give me GTA IV password key pls!
Posted on Jul 16, 2013
2 Suggested Answers
  • 11 Answers
SOURCE: i have a maygay fight night fruit machine and it
whats the name of the manufacture?! the problem will be the hopper, its more likely that it isnt broken, probably just a pound coin jammed up inside it,
Posted on Dec 03, 2010
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
Asus m4a87td Power Surge
Cup of coffee says it is the PS.. First item a surge hits and .......A mo bo will perform a test before it boots up and if all signal voltages are not present properly it simply will not boot up. Hope that your cmos did not get corrupted.
Aug 30, 2017 | ASUS M4A87TD EVO Motherboard
Hello. The problem I'm having with my Wii is that it won't turn on. The outlet is working that its plugged into, but the unit will not turn on. All plugs are in properly, not sure what to do.
hi make sure the power supply is working correctly there should be a green light or amber light sometimes the power supply will surge out when theres alot plugs pluged in the same circuit hope this helps
Sep 27, 2010 | Nintendo Wii Console
No power cannot turn on
Suggest you check the simple stuff first.
Not checking is akin to a car that won't start, and tearing apart the entire fuel system, only to find it was just out of gas.
1) Make sure the receptacle the surge protector is plugged into, has power. Surge protector Power On light should be lit.
2) Check THE receptacle in the surge protector, that the computer itself, is plugged into.
Have had a number of expense surge protectors, where just THAT receptacle was bad.
("Hmmm, surge protector Power On LED light is lit. Monitor, printer, sound system, and router plugged into the surge protector has power. Should be good to go.
NOT!
Plug a table lamp, or similar device into THAT receptacle.
Make SURE it has power)
Surge protector, and receptacle in surge protector checks out?
Bypass the Power On switch.
See if the problem is a $5 Power On switch, or the Power Supply.
(Generic ATX Power On switch that I have found fits many computers,
http://www.directron.com/atxswitch.html
{The Power On switch, is located inside the plastic Power On button assembly}
This is information about computer Power Supply's,
http://en.wikipedia.org/wiki/Computer_power_supply
This is a basic example of an SMPS, (Photo at upper right. You can click on the photo to enlarge), and info about.
(Switched-Mode Power Supply. The main type of power supply used in personal computers),
http://en.wikipedia.org/wiki/Switched-mode_power_supply
By bypassing the Power On switch, you will be able to determine if the problem is the switch, or Power Supply.
Bypassing the Power On switch turns the Power Supply on?
Bad Power On switch.
Bypassing the Power On switch does Not turn the Power Supply on?
Bad Power Supply.
A jumper wire is used on the 20, or 24-pin ATX main power cable.
The jumper wire goes to the Soft Power On, (PS_ON. Green in color), to ANY Ground wire.
(ALL Black wires are Ground wires)
A MOMENTARY contact is used.
(Example of a 24-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24 )
In order to guide you in this procedure, I need to know the computer manufacturer name, and Model Number.
On a desktop computer this will be located on the Back of the computer tower, (Next to the Windows product key), or up on the side of the tower.
Some models have it where there is a door you open in the front, and the product number, or model number is located there.
Post back in a Comment.
Aug 07, 2010 | HP Computers & Internet
My desktop dont come on
1) Check THE receptacle in the surge protector the computer is plugged into.
I have found more than once that One bad receptacle in the surge protector is bad.
"Hmmm, surge protector power on light is lit." "Monitor has power, amp for the speakers has power, and the router has power."
All plugged in to the same surge protector.
Tried a table lamp into the receptacle the computer was plugged into, Nothing.
Replace surge protector.
2) Bypass the Soft Power On of the Power Supply, and see if the problem is the Power On switch, or the Power Supply.
If you bypass the Soft Power On of the Power Supply, and the Power Supply comes on, the problem is a bad Power On switch.
If you bypass the Soft Power On of the Power Supply, and the Power Supply does Not come on, the problem is the Power Supply.
If you wish to know how to perform this simple test, just state so in a Comment.
(Believe upper right of your page)
Jun 17, 2010 | E-Machines eMachines Desktop PC
After a power outage my hp a710n won't respond or restart. a small flashing green light on the back of the hard drive is visible. what can i do?
You hear no sounds correct?
In the best of all worlds, your power supply is dead. That will cost around $50 to replace. If there was a power surge that hit the mother board, you are likely to have a fairly expensive repair.
If you have any sounds from the machine, please report them.
May 22, 2010 | HP Pavilion a710n (PJ508AA) PC Desktop
Fruit machine
my fruit machine has invaild potion display how do i get it off
Oct 30, 2008 | Televison & Video
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Doesn't boot up
try it pluged in without the battery, does it turn on?
when it shuts down, does the power light stay on? or is it just no display?
Jan 04, 2008 | Dell Latitude D600 Notebook
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
