Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
A8 error code
My compressor keeps shuting off on overcurrent safly. What could be the cause if the Inverter is good
3 Suggested Answers
  • 6 Answers
SOURCE: mitsubishi KA6 OVA
Please confirm make model number, don't recognize what you have.
Posted on Nov 14, 2007
SOURCE: found indoor unit running and calling for
Hello Sounds like a restriction/clog if the unit is (pumping down) .try adding freon when the compressor cools off & starts again.See if the low side #s improve.Make sure the service valves are open.
Posted on Aug 20, 2010
I have a 2008 samsung mini split mho50fxca2a with a I trip pfc overcurrent error what is this and where to start? also shows e4 67 which is compressor rotation error?
Your 2 errors are most likely related to the compressor itself and the power supply feeding it. If the system is an inverter system, there is usually an "inverter board" or power control board that sends high voltage (usually in DC rectified voltage) to the compressor. If the board is not functioning correctly or if there is an issue with the compressor, it may cause a reverse rotation error along with the power error. Additionally, the compressor itself may have failed and may have shorted or welded windings. This condition can be especially dangerous due to the potential of electricity arcing and the possibility of refrigerant loss. If you are not a technician trained to work on the equipment, I would NOT advise attempting a repair. Some of the power supplies in those units can discharge over 300v DC and there are quite a few components that can cause serious injury. I would call a technician to diagnose the issue.
Jul 18, 2016 | Samsung MH050FXCA2A 24000 BTU 2 Ton Dual...
Indicator light keep blinking for SHARP ECO INVERTER
The unit has popped up an error code. There is something wrong with the unit. What is the model number? 25325502-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
Dec 16, 2014 | Kenmore Ac Airconditioner Remote Control...
What does error code 461 means on a samsung ?rc140dhxga hide away unit
Hi Jaco,
to trouble shoot this problem,you need to make some eliminations:
1.Check the standing pressure of the refrigerant (gas).If it is low that could cause the compressor to over heat and eventually fail.
2.The compressor could be drawing more current from the inverter causing it to trip.
3.The inverter card could be faulty.Try to run the unit with a similar card from a similar unit before your consider buying a new card.
4.The start capacitor/run could be fault causing the compressor draining a lot of current from the inverter.Inspect the capacitor for visible electrolyte leakage or bulging casing.Try one from working unit.
Regards,
nyauadamson@gmail.com
May 03, 2014 | Samsung Heating & Cooling
WHAT IS AN error code 461
This is a fault to do with the power inverter for your compressor in the out door unit.This is caused by :
1.compressor failure or faulty
2.Inverter card faulty,tr to use another inverter card from a working unit before buying a new one
3.Check that refrigerant standing pressure is adquate
4.Check that the capacitors start/run are not leaking,check for electrolyte leakage.Try one from the working unit
Regards,
Adamson(nyauadamson@gmail.com)
When run comand is enable I get an error OC1. I disconnected the load and still get the same error. The inverter has been working fine for the last three years
Overcurrent on acceleration is what the code is supposed to be. There may be a capacitor failing in the finals of the output stage, or a resistor has shifted value..
Sep 04, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
Can you tell me what service call 7002:0006904 on a Kyocera FS 5030N means? Thank you
7002 is the error code; 0006904 is the printer page count.
Error means-
Toner motor 2 overcurrent detection error (cyan toner)
• The engine controller PWB (A0004)
detected the overcurrent of toner
motor 2.
Possable causes-
1. Lump of toner inside cyan toner container or defectiveness of toner replenishment drive system.
Replace the cyan toner container.
2. Defective toner motor 2.
Replace the toner motor 2.
3. Defective engine controller PWB (A0004).
Replace the engine controller PWB (A0004).
Jan 05, 2011 | Kyocera FS1120D Laser Printer
Found indoor unit running and calling for cooling,outdoor unit was off and came on while hooking up to low side,low side pressure was at 0-1psi.liquid line leaving was frosted up.shut off outdoor unit and...
Aug 20, 2010 | MSY-A17NA Air Conditioner
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Hello have a inverter LG Airconditioner and it keeps turning itself off and showing the letters C6? Any ideas
Error Code: C6 Problem: Inverter compressor run current high
SOLUTIONS:
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s)
Probably best to explain/print out and give to authorised serviceman
Mat
Jul 14, 2009 | LG Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
21 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
