Question about Singer Sewing Machines
Singer 1500 Izek, Presser foot won't stay up.
Undo the foot and tighten the spring
Posted on Jul 17, 2013
SOURCE: singer izek game
Blank gameboy cartridges and backup systems can be purchased at specialty shops online (look to the gameboy music community> link). Once attained, such kit would allow the writing of the Singer sewing game ROM image onto the cart. This would work exactly like the original cartridge. The blank carts should cost around 40 dollars each. The ROM file can be found at the IZEK Yahoo Group or any gameboy ROM archive online.
I was thinking of providing this as a service. But, I've found that most online cart retailers will actually write a ROM to the cart for you for free. So, 40 bones should get you a replacement cart! It used to be near impossible.
Posted on Jan 08, 2009
  • 27 Answers
SOURCE: I have a Singer sewing
more than likeley the set screw is loose on the presser bar shaft ,remove the endcover and take a look should be simple
Posted on Jan 10, 2009
SewTechWayne
  • 186 Answers
SOURCE: faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Posted on Jan 31, 2009
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 51 Answers
SOURCE: singer 6038
The presser bar is not moving, there is a set screw that controls the presser foot height on the bar, it may be to tight. Take the side cover off, and look for the presser bar, the set screw unit should be facing you. Unscrew it and see if the presser bar handel will now move.
The presser bar height should be set at 7 mm. To make an adjustment loosen the set screw. From the top of the machine, press down firmly on the presser bar and then secure the set screw.
Posted on May 13, 2009
Presser foot wont connect
It is most likely the presser foot you are trying to install was not made for your machine. There are so many machines available and most of those machines have their own presser feet, which are not interchangeable. Unfortunately, even a Singer presser foot is not interchangeable with other Singers. Some have screw attachments, others have lever attachments, some have long shanks, others have short, some are straight, others are slanted. You need to figure out what style presser foot your machine takes and then search for either the presser feet that fit or a shank adapter that you can then use snap-on feet (kits are available on eBay).
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Sewing Machine Feet eBay
Jul 17, 2016 | Sewing Machines
Upper tension is to tight on the izek singer machine we have. Also on the bottom of the fabric the thread is looping up and tangeling.
Loops on the bottom mean the upper tension isn't tight enough. First make sure you thread the upper thread with the presser foot UP. Then do a test seam on the same type of fabric. If you still have problems. Tighten the upper tension a little then test seam again. Keep doing this until your problem is resolved.
Nov 09, 2012 | Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
Singer izek model 1500 the pulg on the machine is broke were you plug the foot into machine.
Do you mean the cord? If so, go to www.sewingpartsonline.com and you can order it for $29.95. If it is internal call Singer at 1-800-4singer and they can advise you how to replace it or where to take it.
Jan 25, 2011 | Singer Izek Computerized Sewing Machine
My foot control jack is broke it won't stay pluged in.
try www.sewingpartsonline.com or www.singerco.com and order one. You can call Singer at 1-800-4singer and talk to a customer service rep on Monday. Good luck, Happy New Year
Jan 01, 2011 | Singer Izek Computerized Sewing Machine
Pressure foot does not stay in place...comes loose
Not sure what the problem is.
There is a screw that holds the presser foot shank to the presser bar.
When the presser foot shank is lowered, it snaps onto the presser foot.
See page 26 of the manual - http://www.singerco.com/accessories/manuals.html
Mar 12, 2010 | Singer 7462 Mechanical Sewing Machine
Izek Speed Control
Have you tried removing the batteries and cartridge and re-intalling? Also I learned the pressure foot must be down for my izek to accept setting changes. Hope this helps.
May 27, 2008 | Singer Izek Computerized Sewing Machine
SINGER IZEK MODEL 1500
The Izek has a motor over current protection circuit which measures the currend draw at the main motor. If the main motor is trying to run and it draws more current than it should the machine will stop sewing. In sew speak terms the machine is too stiff to turn easily. There are 2 different solutions. Completely lubricate the machine anywhere metal is on metal use oil (sewing machine) and metal on plastic or platic on plastic use white lithium grease. Try the machine now!
Next if that did not fix it make sure there is no lint, thread or the like wrapped around andy parts of the machine. Good luck
Mar 01, 2008 | Sewing Machines
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
