Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Won't Fill My Zanusi studio compact dishwasher won't run. All the usual lights come on and I can hear the "ticking" but it doesn't fill with water so at the end of a cycle nothing has happened. The water supply is good. I've had this happen before and when I disconnect the supply hose and reconnect it, everything is ok again!
  • Official Brand Answer
  • 4,342 Answers
Hello Ben - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink)
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Verify the inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Confirm that the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some dishwashers use a water pressure switch that will shut off the water valve if the tub over fills.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Posted on Jul 16, 2013
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Frigidaire model # GLD 2250 RD 85. Won't fill with water
see this causes and fix it. God bless you
If there's no water entering your dishwasher, check these:Water-inlet valveFloat switchWater-inlet valveThe water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.Float switchThe float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. To determine if the float switch has failed, watch the part testing video at the bottom of this page.9_25_2012_6_40_24_am.jpg
Posted on Sep 25, 2012
  • 1314 Answers
SOURCE: Fridgidaire dishwasher won't fill
id replace the fill valve just because the fill valve selnoid is good doesnt mean the valve seat is not sticking
Posted on Jun 03, 2008
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: detergent door won't close, dishwasher won't start
    Contact a professional technician to see if the spray loaded action needs to be replaced with a new cup area.
    Posted on Aug 14, 2012
    Bosch SHE44C06UC/22 won't fill with water even though you hear water running somewhere.
    Check to make sure there is no residual water underneath the unit, they have a flood sensor and if it is picking up water in the motor area it won;t run.
    Jan 24, 2014 | Dishwashers
    Tip
    Dishwasher Water Temperatures
    No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
    on Sep 08, 2015 | Dishwashers
    Error code e01
    do the following steps: God bless you
    To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
    To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
    POWER SCRUB PLUS = Heater fault
    REGULAR WASH = Water filling fault (over or under filling)
    RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
    To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
    If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
    If more than one fault occurs, more than one light will be lit.
    Jul 21, 2012 | Dishwashers
    2000 jeep wrangler won't start, good crank, no bus
    Check fuses first, but could be needs new CPU
    Jun 14, 2012 | 2000 Jeep Wrangler
    What is the float switch
    I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
    Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
    Model 655-15974990 won't wash or drain
    What DOES it do? Just fill with water? Or doesn't it even do that? Do you have any lights on or flashing? Do you hear any noises when you try to run it?
    Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
    My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
    The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
    So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
    repairclinic.com
    searspartsdirect.com
    apwagner.com
    apdepot.com
    midwestapplianceparts.com
    Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
    Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
    Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
    Jun 04, 2011 | Dishwashers
    Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
    236 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Robert Roath
    Robert Roath
    Level 1 Expert
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
