Question about Brother MFC-7420 Printer
Fax receiving problem with MFC-7420
Model: Brother MFC-7420. Problem: Can't receive faxes (I think, sending them too). I tried sending fax via online service to myself and it's failed with this reason: "Busy signal detected ; too many attempts to dial" I contacted the support, they checked with me the line and the connections, fax ringing. They tried sending me fax but failed, then they said "The Line and the connections are OK, you should contact a fax technician." Here are the connections: from Telephone <-----------> to LINE (on mfc-7420) from EXT (on mfc-7420) <---> router's TEL2 I played with the fax configuration so far no results. Fax configuration: Initial Setup > Receive Mode > Fax Only Fax > Setup Receive > 1. Ring Delay > 02 Fax > F/T Ring Time > 30 secs Fax > Fax Detect > On Fax > Remote Code > Off Fax > Auto Reduction > On Fax > Memory Receive > On Fax > Polling RX > Standard I tried two drivers (probably it's the same driver but anyway), the one which Windows 7 installs automatically when I plug in the USB cable, and, the second one, on the Brother's official website, on both drivers it's the same situation. Anyone got clues?
5 Suggested Answers
  • 186 Answers
SOURCE: I cannot send nor receive faxes.
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
Posted on Jul 10, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
Posted on Nov 02, 2007
Mix-it-up
  • 832 Answers
SOURCE: Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
Posted on Jan 31, 2008
SOURCE: I want to receive fax in my pc but mfc-7420 (JAY) prints it on paper
 how to send a fax
Posted on Apr 29, 2008
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Won't fax
You have to get your answering machine and your fax to play nice. Read the instructions for both. I think I have my answering machine to pickup at three rings, and the fax to pick up at five. Don't have the fax answer first. Don't have both machines answering at the same number of rings.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
All-In-One Brother 7420 not receiving faxes on home phone. Am trying "easy receive" but all it does is ring... (FYI: I cannot get distinctive ring on my phone). Have already tried Fax/Tel mode but would...
try leaving easy receive on and changing the receive mode to manual. when you pick up phone and hear the other faxs' tone, wait for your machine to take over by listening for the chirps. then hang up. if you don't hear chirps from your machine, then press *51.
hth,
razors
Dec 29, 2008 | Brother MFC 7420 All-In-One Laser Printer
Fax machine sleep mode
have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
I can't sent fax out
hello ! click on menu scroll to fax click menu set scroll down to easy receiveclick menue set the fax should receive now providing you have dial tone on ythe line check with phone plugged in good luck brother sr tech
Dec 09, 2008 | Brother MFC 7420 All-In-One Laser Printer
I can receive fax but i can not sent fax out
go to the set up menu in fax mode and go to quick send and then press ok
One location doesn't recieve our faxes
The problem may be that the other company is running VoIP for their phone system. The Brother MFC 7420 is documented for not having VoIP compatibility as a marketed feature. In other words they were too cheap to include it. However, with that said there is a work around. I have include the link that may be helpful in resolving this issue.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002100/000023/faq002123_000.html?reg=us&Printable=true&c=us&lang=en
Best Regards,
Russ
Apr 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-7420 Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
