Question about Systemax Ascent PC Desktop
Motherboard pin config
I installed a Systemax Venture motherboard in an different case. I need to know what the front panel pin configuration? Thanks.
    Novelist:
  • 231 Answers
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Posted on Aug 28, 2007
SOURCE:
Where can i find specs for my systemax venture desktop
there are specs inside the case, on the bottom, for my systemax venture. there is also a serial number on the back of the tower, on the outside; however, i believe that the systemax desktops were actually assembled by tiger direct.com.
May 20, 2014 | Systemax Computers & Internet
Power hook up wire for DX38BT Motherboard
I don't really understand the question as it is stated. However, Systemax is constructed by Tiger Direct and they should be able toi answer your question pretty quick.
Sep 23, 2012 | Systemax Venture S519J (988868) PC Desktop
DX38BT motherboard wirer hook up.
http://www.intel.com/support/motherboards/desktop/dx38bt/sb/CS-028327.htm
Click on the blue - English Product Guide [ PDF ]
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
Connecting to the Internal Headers
Page 50 for the PDF file page number. Figure 27. Internal Headers
The front of your computer is the Front panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Item I in Figure 27.
Detailed connections on Page 54.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 23, 2012 | Systemax Venture PC Desktop
Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Nov 12, 2010 | Computers & Internet
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything from the OEM case into a HTPC 8000 Media Center Case. I need to know the F-Panel pin configuration in...
this is your standard front panel configuration. the wires from the case should have different colors for positive and negative. the colored wired is usually positive and the white typically negative. please refer to case manual for clarification. you can also test to make sure this is where the power switch location is by "jumping it" with a flat head screw driver. i would do this to verify the location first. again this is simply the standard configuration and i can't guarantee that your board is set up this way.
hope this was helpful.
Dec 09, 2009 | Gateway Computers & Internet
CAN'T FIND ETHERNET CONTROLLER DRIVER FOR MY SYSTEMAX VENTURE SERIAL #106722446. DOWNLOADS FROM SUPPORTFORYOURPC.COM DIDN'T HAVE THE DRIVER.
You can always use a program like driver genius or Boot from a Knoppix cd and run ls pci from the command window. If the card is not integrated in the motherboard pop it out and get the numbers off the card itself.
Worst case scenario is put a 10 dollar pci ethernet card in it :)
Aug 22, 2009 | Systemax Venture PC Desktop
I need a sound driver for systemax venture
Hi
Firstly, try getting the motherboard model and checking the manufacturer's site.
You could try drivergrabber off majorgeeks.com (easily found on google). Alternatively, try googling the device ID's - found by clicking start > run "msinfo32" OK. In that screen, click the [+] next to components and then go to Problem Devices. In that screen, on the right hand side, you will have things written such as PCI\VEN_8086&DEV_3A3A - go to google and type in exactly as follows "8086 3A3A" (or whatever shows up after VEN_ & DEV_ in your case) and see what you can find.
Alternatively, if you're running a legitimate copy of Windows, Windows update (if on XP you must install Microsoft Update), can often pull these straight down off the Microsoft servers.
Dec 15, 2008 | Systemax Venture PC Desktop
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
Systemax Ascent PC Desktop Logo
343 people viewed this question
Top Systemax Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
