Question about Jet 321530 GH-1660ZX Spindle Bore Precision Lathe With 3-axis Acu-Rite 200S DRO Installed
Wiring diagram for grundfos ma4pl 2.2 kilowatt with auto /manual switch...
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
How to connect iton to 220 volts
http://rainwatercollection.com/download/Grundfos-Manual.pdf
From what i have researched you have to buy a 120 volt pump or a 220 volt pump you cannot wire it both ways. The pictures shown on that pdf show where to put the line 1 and line 2
Oct 10, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
Wiring diagram for grundfos pump
It depends partly on your phase and voltage requirements, but here is a picture of some options.8_7_2012_4_14_07_pm.png
Aug 04, 2012 | Grundfos Pumps Grundfos CH4-50 11 2Hp...
2004 buick ignition switch
I can't copy a full diagram page to the answer box. You can look at auto zone online and other websites for wiring diagrams.
Auto zone has repair manuals for most cars with diagrams too.
Jul 28, 2012 | Cars & Trucks
I just recieved a grundfos add on timer for my small circulating pump the wiring diagram is not clear need some advise on how to wire
More information is needed. Add a comment.
Grundfos makes many models and many parts.
http://www.plumbersurplus.com/Prod/Grundfos-24-HR-Programmable-Clock-Timer-%28505474%29/11040/Cat/680
You do not say what wires what are available, or what the instructions say, so the expert is left guessing.
Guessing: Normally this type of timer module has at least 4 or 5 wiring terminals.
Two terminals power the clock motor, and two terminals are for the switch.
Example wiring: power from circuit breaker connects to terminals 1 and 3, line going to motor connects to terminal 4, and neutral from breaker box and neutral going to motor connect to terminal 2.
http://waterheatertimer.org/images/FM1-wiring-280.jpg
Another basic wiring plan same as described above:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
Add a comment with exact information shown in instructions, and what wires you have, and what each wire goes to.
Of add a comment with in-focus photo posted on flickr.
Open following link for recirculation system resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 06, 2011 | Grundfos 505474 24-Hour Progammable...
I've had my Grundfos Up1510SU7P for about 5 yrs. Recently, it started sending scalding hot water to the faucets. Could it need a new value? I've tried to find a manual for this for any...
It sounds like thermostatic operation is not working.
I cannot offer specific repair, but can offer resources
1) Grundfos service options and warranty information + local distributor of parts and service center finder:
http://www.grundfos.us/web/homeus.nsf/Webopslag/OMAT-5S7J7X
2) Terminal strip and capacitor replacement does not show UP1510SU
http://www.us.grundfos.com/Web/Download.nsf/Pages/F3A9576228BA79AF0825691A006D2D0F/$File/Luptl028.pdf
3) Open following link for recirculation system resources including some manuals, but I don't have your exact manual.
I can see your product on following link
http://www.houseneeds.com/shop/plumbing/recirculators/waterrecirculatorindex.asp
4) Recirculation systems operate 2 ways: with thermostat or timer.
Thermostat is supposed to turn off circulation when water reaches 100 degrees approx.
Until thermostat is repaired, you can work around problem by moving slide switch to TIMER and set timer to run intermittently so temperature at faucet is moderated.
5) Adjust temperature at water heater
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Grundfos UP15-10B5/ATLC 1/25 HP ...
How to program timer?
Diagram showing timer tabs being pushed in or out to set programs:
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
Grundfos illustrated installation guide
http://waterheatertimer.org/pdf/Grundfos-L-UP-TL-043-install-photos.pdf
Rotate programming ring clockwise until current time lines up with arrowhead on inner dial.
Current time must be reset after power outage.
Tabs located around programming ring control timer functions.
Each tab represents 15 minutes.
Tabs push in or out using a pen.
Tabs out = grundfos ON
Tabs in = grundfos OFF
Set manual switch to TIMER and timer program operates pump
Set manual switch to ON or OFF to override timer program
Dec 04, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Need wiring diagram for windshield washer button on turn signal lever to disconnect switch and rewire push button in its place
Go to Auto zone or Advanced Auto Parts and bye a Haynes Repair Manual It will be in there. There is way too much to tell you on this. Over 2 pages in the book with diagrams. It'll cost you about $20.
Jake. B.
Jun 17, 2010 | 1998 Ford Windstar
Iam attempting to fit a new dual cord to my steam generator model 2935 and I have misplaced my drawing of the connections to the iron. Is it possible to get the wiring diagram for the electrical...
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Dec 24, 2009 | Tefal Irons
Jet 321530 GH-1660ZX Spindle Bore Precision Lathe With 3-axis Acu-Rite 200S DRO Installed Logo
35 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
