Question about Hardware & Accessories
Chain seems to be to small - Hardware & Accessories
Get a bigger chain
Posted on Aug 22, 2013
My Husqvarna 350 bogs down and is not turning the chain.
something is pinching the chain when you have the side cover on. either the bar isn't sitting flush to the saw or you don't have the chain in the sprocket correctly and that is causing it to bind
Jan 27, 2013 | Husqvarna Garden
Chain won't move after chain replacement
Had this happen to mine when I was limbing stuff that was too small. I know better. There is probably a burr on one or more of the guide portion of the links where they run in the bar. This causes that link to be tight in the bar at this point. The chain probably hit something on the body of the saw when it flew off. Take the bar off the saw and run the chain through the groove in the bar. If you have any links with nicks, they will bind, causing the chain to stick and not run freely. Once you've identified the problem links you can remove the nicks using 120 grit paper backed up with a flat piece of steel so you only remove the high spots.
May 05, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
. Bought new chain 90sg-56. Chain does not fit
either the bar is bent, or the grove that the chain sits in has been pinched or has a small ding or dent in it, check the entire bar, also, the entire grove,, even a small piece of wood shaving that has become lodged in the grove will stop the chain once its been tightened in place. remove the bar and lay it flat on a even surface, a window glass works good for this, if it isn't completely level,, you will get binding
Oct 07, 2011 | Garden
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a homelite i350b chainsaw and the bar and chain oil doesnt seem to be oiling the chain when using it.?
Remove the chain and bar.
Clean away any sawdust and shavings which have built.
There should be a small nozzle under where the bar was attached. Ensure this isn't clogged.
Feb 16, 2011 | Garden
After 10 mins cutting small logs the chain becomes lose and i have to re adjust
If the chain is quite dull, the increased force required to make a cut will overheat the chain causing it to stretch. So will reduced lubrication to the bar and chain. Run the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil. If it seems to be stingy with the oil, remove the bar and chain (release the chain brake first) and run the engine for a bit to see if the side port in the engine oozes oil out. If ok, clean the two small oil passages that run from the large holes out to the chain groove on each edge. When re-assembling, adjust the chain just up to the bar, but not so tight that you can't turn it by hand. Hope this helps!
Nov 14, 2010 | Garden
Chain not lubricating
Remove the bar and chain. Clean all parts exposed including the bar drive-end small oil channels that feed oil out to the chain groove on both sides of the bar. Start the engine and look for oil oozing out of a small side port where the bar fits to. If ok and no oil seems to coming from under the case, reassemble all components. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw in the case back near the lower run of chain or just under the case in the same area. Turn CW to reduce volume. Hope this helps!
Jul 06, 2010 | Husqvarna Chain Saw 20" Bar
Chain jammed on plant won't run after pulling most of plant from inner part of chain. Makes humming noise
The humming is the motor trying to turn. Remove the drive end cover from the bar and chain--back off the chain adjustment CCW several turns. If the saw has a chain brake, release it. When the cover is loose, remove the bar and chain, inspect the entire mechanism for any damage--particularly the chain itself. Run the motor without the bar and chain, and check for oil oozing out of the side port in the motor case where the bar fits. To reassemble, fit the bar in place after cleaning the small oil passages in the drive end, then fit chain over the sprocket. Pull the bar outwards to tighten the chain, then fit the cover and fasteners finger tight. Adjust the lower run of chain up to the bar (the lower run of teeth cut toward you), but not so tight that you can turn the chain by hand. Tighten the fasteners and recheck chain tension. Chain saws don't seem to like cutting hedges and other small branch, but tough bushes and the like. Make sure the chain teeth are properly sharpened. Hope this helps!
Jun 24, 2010 | Remington 16" Electric Chain Saw
Hardware & Accessories Logo
321 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
