Question about LaCie Computers & Internet
10007 it wouldn't open on MackBook Air
  • 3 Answers
Give me a nero6 serial number
Posted on Jul 16, 2013
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
2000 dodge grand caravan 3.8L. the a/c stopped cooling, the next day the serpentine belt broke so I replaced it. It wouldn't start so I had alternator tested, it was bad, replaced it, still...
sounds to me like a siezed up ac unit.. it would not spin while all other pulleys spin... thus causing the broken belt.. hope that helps you
Aug 03, 2011 | 2000 Dodge Grand Caravan
Russell Hobs Juice Lady ....10007 it makes a lot of noise and is not juicing ...what is wrong? we don't have the user manual
THIS HAPPENS WHEN THE COUPLERS OR THE SHAFT ARE WORN OUT. REPLACE THE SAME AND IT SHOULD RUN FINE(THE PART CONNECTING THE JAR TO THE BODY)
REGARDS.
Jul 03, 2011 | Russell Hobbs Microwave Ovens
We purchased a Kenmore Window Type Room Air Conditioner Model 23.70062 about three weeks ago. Tonight, as I was sitting next to it at my computer, I smelled a funny odor which seemed to come from the air...
Well, if you are concerned about the refrigerant leaking, you don't have to be,it's nontoxic- I wouldn't recommend breathing it and it could make you dizzy but not bad in any long term way. if you can handle turning it back on and it still cools, then you probably haven't lost any charge. I would check the filter next-maybe it got contaminated somewhere, or maybe there was some wire insulation getting hot. I wouldn't attempt repair- The store should exchange it for you
Jul 03, 2011 | Kenmore Heating & Cooling
I suffer from a build up of steam in my bathroom, I have an extractor fan and was wondering if fitting a humidistat may help.
If the build up only occurs when the shower is operating, it wouldn't be worth the money, time and effort. Check the fan, by removing the cover. It may need a good cleaning. As they do collect dust, lint and hair when they are in operation. Also, running it properly, may solve the problem. The fan should be ON prior to starting the shower and remain on at least 15 minutes (some manufacturer's recommend 30 minutes) after the shower is completed. If you bathroom has a window, opening that at least 1/2", allows the fan to pull in fresh air to help eliminate the humidity. Of course, in the dead of Winter, you don't want to open the window. As the cold air will turn the humidity/steam into water droplets.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | Honeywell Heating & Cooling
1998 Nissan Maxima studdering at idle and up hills between 1 & 2 RPMs. Mass air flow sensor? Also hear a hissing maybe a vaccum leak?
That vacuum leak would be causing your studder. The air flow sensor would be able to read the air coming in from a leak and wouldn't add the right amount of fuel. It would lean out, meaning it would have too little fuel for the given amount of air and just wouldn't have the power it needs. I find vacuum leaks by pinching vacuum lines until the hiss goes away and then follow that line to where it leaks. Vacuum line is cheap, less than a buck a foot, so this fix would be cheap and easy to do.
Apr 19, 2011 | 1998 Nissan Maxima
Computers & Internet Logo
13 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
