Troubleshoot oral b oxyjet the charger doesn't work
Troubleshooting oral-b toothbrush
Make sure the contacts on the bottom of your brush are clean as this sometimes gets tooth paste on the contacts and stops it from charging.Failing this take it back to the shop you purchased it from if under a year and ask for a replacement.If the shop manager is any good he or she may plug your brush into another charger to see if it is that and not the brush itself.
Sep 28, 2017 | Oral-B Toothbrush Health & Beauty
To charge a oral b electric toothbrush does it sit on the charger so the toothbrush is loose
It uses an induction charging system. It is the centre of a transformer and the base is the primary.
Not very efficient but works. It sits loosely on it.
Aug 06, 2017 | Oral B Health & Beauty
Why does the light flash constantly while in the charger
Clean your battery contacts off in your charger as well as the tooth brush Dirty or bad contacts will do this.
Apr 12, 2015 | Health & Beauty
Why is my oral b braun B Professional care 500 not charging
Test the voltage of the charger base. This is a simple method to see if your brush is getting power from the base. Touch the metal connectors with the voltage tester. This should light up the tester. If not, it is losing electricity somewhere within the base.
Apr 23, 2012 | Oral B Braun B Professional Care 500...
Oral-B 12V charger?
I am looking for exact the same as this. Braun should make a 12-volt charger to their tooth brushes. It shouldnt be too complicated and very well possible as the battery in the handle is only below 6 volts.....!
Feb 17, 2012 | Oral B Braun Oral b 3d Excel, Pro Care &...
Hi, i have problem with my toshiba satellite a135-s4527 doesn's work drivers
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Apr 27, 2011 | Computers & Internet
My Oral-B Sonic Complete stops working afer 2x use despite being on the charger always.
These toothbrushes need to be completely discharged every six months or so to keep the battery fresh. Maybe the battery has packed in.
Take it out of the charger and turn it on till it stops completely then re-charge. It might kick start the battery.
Mar 28, 2011 | Vacuums
My oral b rechargeable toothbrush (brand new out the box at the weekend) wil not recharge - have thrown the intructions away thinking "what is there to know you stick the toothbrush on the charger...
The plastic connecton has a coil in it, much like how a transformer is done. If you read up on how a transformer works its pretty much the same principle as it works on Induction. There is a coil and core iron in the end of the toothbrush and in the base, this creates AC current which inturn causes induction to flow through the coils and charge the battery. And about the reason why it is not charging is probably down to the battery being flat ( happens even when new ) or there is a loose connection when it was being transported.
Hope this helps.
Mar 22, 2011 | Oral B Vitality Dual Clean Rechargeable...
How long does it take to recharge my oral b toothbrush and should it work when put on charger sraight away
The first time you use the unit, it should be charged for 24 hours or more.
When it needs charging, my unit takes over 24 hours to fully charge and then lasts around 14 days until it needs another charge.
Is this helpful?
Gary
Feb 28, 2011 | Vacuums
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
