Question about Clarion APX480M Car Audio Amplifier
Clarion APX480M amp
My Clarion APX480M amp will power on(the green LED is lit up on the amp) and sound comes out of the speakers, but the music is very hollow sounding. The subwoofer amp is also making a hissing/scratchy sound that you can hear when you hold your ear up to it. I have two of these amps in my boat so I am not sure if the problem is the stereo or amp(s). I have one driving 4 7" clarion speakers and the other is driving 2 subwoofers. Either way, I went from sounding cool on the water to not being heard at all.....:):) Any help is greatly appreciated. Thanks, Jason
This sounds like a signal problem. Make sure that all of your signal cables are plugged in fully. If all are, you need to check for coninuity between the shield ground of the head unit's RCA jacks and the case of the head unit. With no RCAs plugged into the head unit, you should read ~0 ohms between the shield of the RCA jacks and the case of the head unit.
Posted on Sep 09, 2007
SOURCE:
Green led on , but no sound when speaking through microphone
Sounds like an attempted amp/PA mixer repair to me. Plug a guitar or music source into one of the inputs and see if you hear anything. Honestly, the protection relay circuits rarely go bad but instead are reacting to problems elsewhere in the circuitry. Good luck.
Jan 31, 2013 | Audio Players & Recorders
I have a clarion axp480m. the power light is blinking blue and it will not allow sound to the speakers.
Tried all that and still mine is in protect mode. Every other amp works fine on the wires but that amp is an epic fail. Solution: DO NOT BUY THIS TYPE OF AMP...
May 19, 2011 | Clarion APX480M Car Audio Amplifier
My Clarion APX480M marine amp cuts out at random
try to unplug each speaker one by one while playing it. There can be a defective speaker that grounds out at the speaker terminal or internally causing the amp to go into protection causing all the speakers to go out.
Jun 05, 2010 | Clarion APX480M Car Audio Amplifier
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Nov 09, 2008 | Clarion DB538RMP CD Player
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Fuse for pwr amp.
For a single Clarion APX480M, the inline fuse should have a rating of 40 amperes.
Incidentally, perhaps a copy of the installation manual would be of use to you. One is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Car Audio & Video
Power and led on but yet no sound
red means protect, check speakers first then disconnect all power,try again in 20 min
Aug 22, 2007 | Visonik V900XD Car Audio Amplifier
Clarion APX480M Car Audio Amplifier Logo
371 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
