Question about Scotsman CU1526SA-1A 150 Lb Self-Contained Cube Ice Machine - Prodigy Series
Cu15265 is installed but we cannot find toggle switch to turn on
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Remove bottom cover and switch is behind it
Posted on Jul 03, 2014
How to turn on my alarm on Toyota celica 1997
There was not a factory installed alarm for this car, any "toyota" security system would have been instaled at the dealer or the regional distribution port depending on what region the car was originally sold from. Do you have a remote for the system? Also check for a red valet button on the dash that can be toggled on/off. The port systems are also known for toggle switches located on the driver kick panel or under the driver dash. If you don't have a remote and manually unlocking the car from closed driver door will not disable the system you will have to locate the toggle/valet switch.
Dec 19, 2016 | 1997 Toyota Celica
Have a 97 honda. Just purchased. It has a toggle switch installed that works with original key ignition. That said... toggle controls whole electrical..everything works..except tail lights,and the dash...
So If I understand, you turn on toggle and then use key to engage starter? Do brake lights and turn lights work, just not the running lights? Or are all tail lights dead. If none work, juice is not getting to the headlamp switch. Best fix would be to replace the probably bad ignition switch and repair wiring back to original, but quick fix would be to run a second wire from toggle switched side to the headlamp switch +
Dec 18, 2014 | Cars & Trucks
How do i turn the wifi on my compaq nc8000 after installing the wireless card
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 08, 2012 | HP Compaq nc8000 Notebook
Where is the wireless radio switch
Jun 05, 2012 | HP Computers & Internet
Where is the red switch that is turned off when servicing Audiovox pretige remote car starters?
there is usually a red toggle switch down in the kick panel or on the knee bolster. It is silver and has a red rubber boot on the toggle switch. This may not be there if the tech did not install it.
Dec 06, 2010 | Car APS921 Remote Starter - Keyless Entry
Can't turn off built-in alarm
There should be a toggle switch that was installed with the alarm system, may be down by your left leg when sitting in the drivers seat. With the key in the ignition and turned to "on", flip the toggle switch twice to turn off the alarm.
Mar 19, 2009 | 2000 Toyota ECHO
I need to know how to wire my deck.
buy a toggle switch
run a wire from the red wire located at the back of deck
to the deck and toggle switch (power to power on toggle switch)
do the same with the ground wire (black) (ground to ground on toggle switch) (make sure to follow logos on toggle switch)
finally install e brake wire to center pin on toggle switch
now you can watch make sure toggle switch is on
if this didn't work switch the e brake wire and black wire on toggle switch
good luck hope i helped
Dec 08, 2008 | Pioneer AVH-P5700DVD Car DVD Player
I have a dual brand car monitor stereo that won''t show dvd
hi there
well to start the e-brake will need to be applied to allow you to see the video if it was installed correctly.................to over ride this feature you need a toggle switch with 3 pins on it
on the toggle switch there should be two logos (power & ground) if you run a small wire from the red wire from the back of your in-dash system to the toggle switch (power) and do the same for the black wire (ground wire)..........the last pin on toggle switch you attach the e-brake wire from the back of your in-dash system to the toggle switch pin and turn it on video will play
if this doesn't work switch the e-brake and ground wire around on the toggle switch
hope this helped
Nov 28, 2008 | Car Audio & Video
Multiple switches/multiple amplifiers
All the amps should be wired directly to the battery, with a toggle switch on each of them. most amplifiers have a SWITCH wire as well, shich is usually wired to your ACC wire on the stereo. instead, run each SWITCH wire to a positive wire through the toggle switch. If done right, you should be able to run each amp on a separate circuit and can turn them on or off as you wish.
Oct 22, 2008 | 1986 Honda Accord
Scotsman CU1526SA-1A 150 Lb Self-Contained Cube Ice Machine - Prodigy Series Logo
47 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
