There are many factors to consider:
This should get you started, only you can decide if it's worth it.
I think using illuminated sign is good for your business. For more details you can visit Dynabuild.
According to the International Sign Association, it's a good idea to have an illuminated sign because it will help to advertise your business even in the middle of the night when the shop isn't open or in bad weather. You can find more info on their site here: http://www.signs.org/SignIndustry/Signage101/TheRightSignforYourBusiness.aspx
The MIL turns OFF after the engine is started if a diagnostic fault is not present.
The MIL remains illuminated after the engine is started if the control module detects a fault. A diagnostic trouble code (DTC) is stored any time the control module illuminates the MIL due to an emissions related fault. The MIL turns OFF after three consecutive ignition cycles in which a Test Passed has been reported for the diagnostic test that originally caused the MIL to illuminate.
The MIL flashes if the control module detects a misfire condition which could damage the catalytic converter.
When the MIL is illuminated and the engine stalls, the MIL will remain illuminated as long as the ignition is ON.
When the MIL is not illuminated and the engine stalls, the MIL will not illuminate until the ignition is cycled OFF and then ON.
