Question about Coffee Makers & Espresso Machines
Sc 282 error code in aficio 1232c - Coffee Makers & Espresso Machines
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: Ricoh Aficio 1232c is flashing SC 792
that appears to be a finisher communication problem. Check the connectors..
Posted on Mar 27, 2009
Ickoajnc
  • 203 Answers
SOURCE: Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Posted on Jul 15, 2009
copyalbania
  • 96 Answers
SOURCE: ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Posted on Aug 13, 2010
Code 792
SC 792 :Finisher error .The machine does not recognize the finisher , but recognizes the relay unit .Possible causes :Defective connectordefective cable incorrect installation
Apr 01, 2014 | Ricoh Aficio 1232C Color Copier
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
Error code 873
sc 873 is the hard disk failure. replace the HDD.
Dec 21, 2010 | Ricoh Aficio 1232C Color Copier
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Mar 27, 2009 | Ricoh Office Equipment & Supplies
Jan 09, 2009 | Office Equipment & Supplies
Press yellow key
key in 1,0,7
Dec 15, 2008 | Ricoh Aficio C811DN-T1 - printer - color -...
Coffee Makers & Espresso Machines Logo
18 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
