Question about Home
Why is a spoon rest necessary? - Home
    Problem Solver:
  • 6 Answers
Spoon rests are very useful for keeping any food from staining the counter while cooking and at the same time protecting the spoon from touching any contamination that might be on the counter
Posted on Jul 16, 2013
What is the best material for spoon rests?
Spoon rests are made of different materials like wood, plastic, glass and ceramics. I personally believe the worst to be wood because it absorbs very easily any liquid and never really gets cleaned well. Plastic also absorbs, even tho much less than wood, and is much easier to clean. But, like wood, will probably retain the odors.
The best option I believe is ceramics, because is more commonly found than glass spoon rests, and is strong, easy to wash and doesn't absorb odors.
Jul 16, 2013 | Home
How do i make a trivet from corks?
Easy ste by step instuctions. If you haven't already started, start collecting those corks!
http://catbee.wordpress.com/2011/02/28/cork-trivets/
Jan 14, 2013 | Home
What is a trivet?
A trivet is an object placed to spearate the dish and the table. It is used when a dish or hot or watery, in order to protect the table from any possible damage.
Jan 14, 2013 | Home
GE Twenty-Eight Hundred Dishwaser says blocked washarm, but isn't Code C5
If you've checked that nothing is in the way (no spoons hanging down, etc) just press and hold start and it will start up again and probably won't reoccur for the rest of the cycle. Our dishwasher started doing this near the end of its life....
Feb 23, 2011 | GE Dishwashers
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
Buzzer goes off
This was the answer from Presto as I had the same problem. Cleaned it with window cleaner and a wooden spoon and paper towels and now it works great!
Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Dec 29, 2009 | Presto HeatDish Compact Heater
Plastic spoon melted on ceran stovetop. Used a
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Aug 24, 2009 | Whirlpool RCS3014 Electric Cooktop
Home Logo
809 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
