Question about Intel Computers & Internet
Setup entry key detected enter password unlock system
BIOS is in "view only" mode, can't be edited and OS is not loading, but HDD & OS is ok
  • Intel Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on Jul 16, 2013
2 Suggested Answers
SOURCE: pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Posted on Dec 21, 2009
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
How to unlock hdd/ssd password on toshiba satellite l655-s5153
Step 1Turn on your laptop. Press the "F2" key when the first loading screen appears. This will load the BIOS. You'll only have a second or two to press this key before Windows begins to boot. If you're not fast enough and the Windows screen comes up, simply restart and try again.
Step 2Use the right-arrow key to highlight the "Security" tab. This is the third tab from the right.
Step 3Press the down-arrow to enter the Security Settings menu. Scroll down to "User Password," listed beneath the "HDD/SSD Password Select." This will open a pop-up window with three text fields.
Step 4Type your current password into the "Current Password" field. Press "Enter." Type your new password into the "New Password" field and press "Enter." Type the same password again into the "Confirm New Password" field and press "Enter." The "Password" window will close.
Step 5Press the "F10" key to save your new settings and exit the BIOS. Your laptop will now boot normally.
Tips & WarningsHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
Mar 24, 2012 | Toshiba Computers & Internet
Hard d bios password
to change the password, do this:
1. go to into "setup" from the boot up entry (turn on comp, then press F2 or F12, depending on your OS; look for them in the bottom left corner; if you don't press it before the OS loads, you'll need to restart and do it again)
2. Once in setup, you'll see a menu bar - for each item on the bar (i.e., File, Edit etc) select F9 and select yes when prompted to save changes. Do this for each. Then go to the Menu Bar Option that will allow you to change the password. It will ask you for the old password - do not enter anything - simply hit enter - then hit enter for the new password entry, as well as the "confirm" password entry (if applicable, should be).
Then, go to exit, and "exit saving changes". The OS will automatically reload. If and when you are prompted to enter a password for the OS, hit enter. You should be brought to the OS (windows) desktop.
If this does not work, please let me know.
Jan 23, 2012 | Computers & Internet
NO KEYS FUNCTION AND ALL I SEE IS NTLDR MISSING BUT NO KEYS WORK TO GET TO BIOS
NTLDR missing is typical of Windows not findind some system files during the boot, I believe nothing wrong with the hardware.
First enter in the BIOS and be sure that in the boot device list you have the CD or DVD before the HDD.
Second Boot the PC from CD with the Windows CD and try to repair the Windows installation.
http://download.lenovo.com/pccbbs/mobiles_pdf/45n3684_01.pdf
To enter the BIOS Setup Utility, do as follows: 1. Turn on the computer. 2. When the Lenovo logo comes up, immediately press F2 to enter the BIOS Setup Utility.Note: If the customer has set a supervisor password, the BIOS Setup Utility menu appears after the password is entered. If the customer has set a user password, you can start the utility by entering that password; however, you cannot change all of the parameters.
Please let me know if you need more support.
Best regards
Mar 11, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
No operating system found
check the bios setup for hdd detection if hdd detected in bios then reinstall or repair your OS
if hdd not detected by bios setup then you have to open hdd cover
you will find a fpc cable betwen hdd & mother board
just open the connector carefully & refit & apply a small tape pice on the connector lock after reinsert the cable
Feb 19, 2011 | Samsung X05 Notebook
Can't unlock My Essentials 1TB Hard Drive Asking for password and I don't have it.
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital My Book Essential Edition...
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
Pc "bios"problem
Dec 21, 2009 | Intel Computers & Internet
Cant detect hard drives during the process of loading xp
Just pres F2 key on startup. Go into bios. In bios find HDD and press enter next to mode. Select IDE mode and press f10 to save changes and exit. You can install XP now. Alternatively you can use USB floppy drive to load SATA drivers.
Let me know if you need assistance on that
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
193 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
