Question about Whirlpool AWM8123 Front Load Washer
F18 - Whirlpool AWM8123 Front Load Washer
Setting up a formula. I am comparing amounts for the last 3 years of raises and want to figure 5 different ones this year.Example of what I am trying to do. =(F6:F18*1.12%+F6:F18) Can this be done?
in excel ?
=sum(f6:f18)*0.012+sum(f6:f18)
if each row has to be individually * 0.012 add a column and put in this column each row cell * 0.012. example new column G then g6=f6+f6*0.012
a screen print of what you are trying to do would give a clearer indication of exactly what you want to achieve ?
Mar 26, 2017 | The Computers & Internet
Car won't start after cutting off?
that is a fuse for the power train control module. so the mudule is failing.
Dec 28, 2013 | 2003 Jaguar X-Type
F18 fuse keep on short circuiting
find what fuse 18 runs and check it for a dead short. If it is a fuel pump fuse check the fuel pump for seized or dead short.
Dec 28, 2013 | 2002 Jaguar X-Type
F18
I'm afraid you need an engineer for that kind of problem.
F18 indicates a control unit error.
Jun 06, 2011 | Whirlpool AWM8143 Front Load Washer
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
Mar 05, 2011 | Washing Machines
What is error code F18 please?
F18 means the filter is blocked. Look around for a propeller shaped part - it should be able to spin freely. If not, remove the debris so that it is unblocked. Good luck!
Feb 28, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
My washing maschine says F18. What does that mean?
If you let me know the Make of the machine, I can tell you exactly what F18 code is and what needs to be done to repair it.
Dec 31, 2010 | Washing Machines
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Whirlpool AWM8123 Front Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
