Question about Kitchen Ranges
Smeg uk60mfx1 the fan oven has stopped working. the mains fuse is still working but none of the cooker is functioning. can you help
SOURCE: electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
Posted on Jul 28, 2007
  • 209 Answers
SOURCE: smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Posted on Sep 09, 2007
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
New (graded) smeg scp399x-8 no heat on any of the functions
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 07, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Blows mains fuse
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
Nov 30, 2011 | Smeg Ovens
Smeg electric oven model sa22xmf/7 not heating at all after power turned off
Nov 29, 2011 | Smeg Ovens
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Suk92mfx5 main oven problem?
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
