Question about Adhesives, Coatings & Sealants
Why is caulking important or useful in private homes?
    Problem Solver:
  • 6 Answers
By sealing cracks and leaks around the house you save energy, reinforce both house and appliances, prevent bigger repairs, therefore saving money, and you increase the lifetime of appliances, which decreases the amount of waste and pollution
Posted on Jul 16, 2013
Someone told me to put ge silicone sealant over freshly cured silicone caulking to give it a smooth look before painting. now i have a real mess. sealant won't cure what do i have to do
Hey Lorrie,
I am sorry someone gave you this info.. You will and probably have to remove ALL/BOTH the caulking and silicon and then redo the caulking all together. You can use your finger to smooth the caulking.. and you can paint over it when its dry,,,
Jun 22, 2017 | GE Home
How do i caulk my bathtub
get caulk and a caulk gun at the local hardware or Walmart. Load the caulk tube into the tray part of the caulk gun, snip the end of the tube. push on the rear of the tube and slowly lay a bead of caulk around the area of the tub needing caulk.
Apr 13, 2017 | Home
Can this be adjusted / setup for a single cartridge
Buy a single tube caulking gun, you will have more accuracy and less weight, you can buy a good cheap model for about $10 at Home Hardware..
Sep 30, 2014 | Newborn Brothers Newborn 515 20 Oz....
Hole in wall
The hole was probably put there for a dyrer vent, which is very important to have. They allow heated moisture vapor to be expelled outside and helps keep excess moisture out ot the home. If this is the case, any home improvement outlet will have the stationary wall plates and the outside flap mechanism. The flap shuts when not in use and keeps outside elements out of your dryer......including critters. If your dryer is vented already, just cover the inside of the old hole with a piece of panelling, insulate the hole space, and attach a metal cover over the outside of the hloe. Make sure you seal the outside with caulk or another sealer.
Sep 07, 2014 | Dryers
Video on calking tub to floor
I would suggest using 'relief cuts' in the strip so you can make the bend, and then continue -- though using a caulk gun would be better. With standard caulk you can just use your finger and a little water to leave a nice finish. I believe you will find it cheaper as well -- a tube of caulk is around 2 or 3 dollars -- and a caulk gun is a dollar or so.
http://youtu.be/qARPdyLwkb0
Jun 21, 2014 | Home
3 piece tub needs to re-caulked. Is this a do it yourself project?
Are you talking about caulking around all sorts of small tiles, or is yours a one piece wall unit that only has caulking around the edge of the tub and the nozzels? If it is the latter, you simply remove the old and add new. If it is all the old tile caulking then If you are not good at handyman (handywoman) things, then you should call a professional. Most of the home outfitting places have help available to you if you wish to DIY the job. You should visit a place like Home Depot, Lowes, etc. for their free advice and a lot of them offer classes in home repair things.
Jan 26, 2013 | Home
My newly tiled shower(app.2 yrs. old) needs to be reclaulked. The caulk used has broken down & looks like it melted onto the floor?? I would like to know what the best caulk is for re-caulking this...
You will need to clean as much of the old caulking from joints that you can, After scraping old caulking out then wash with cleaner such as soft scrub and rinse thororghly. Let dry and wipe any residue with clean cloth.
The best all around tub and tile caulk and adhesive that I've found is called polyseamseal. It comes in almond which is pretty much the same as other caulks bone or beige. It applies easily and you can wipe off excess with fingertip as it is a latex base product.
What I do is apply as thin a bead as you need and wipe with damp fingertip, cleaning excess from fingers often. Continue wiping till you are satisfied with joint. VERY IMPORTANT: Keep completly dry for 24 hours. It will skin over in a couple of hours but it really needs the full drying time.
After it is dry there will be a light film around joint, use damp rag to wipe this film clean. It's not unusual for it to have a slight film on it more than once so don't worry about it.
I have been using this product for 30 years and if used right it has always made my customers happy. I hope this helps you. Thanks
Dec 14, 2010 | Home
Table creation via textfields using swings
import java.lang.Object;
import javax.swing.table.DefaultTableModel;
public class tabletest extends javax.swing.JFrame {
String[][] row = null;
String[] title=new String[3];
private int i;
/** Creates new form tabletest */
public tabletest() {
initComponents();
setTitle("table test");
setVisible(true);
System.out.print("NO Database Needed");
title[0]="Name";
title[1]="Desig";
title[2]="id";
" In middle of this two source one generated code will be there that will be done by dragging ur fields to ur frame. THIS IS FOR netbeans IDE "
private void b1ActionPerformed(java.awt.event.ActionEvent evt) {
row=new String[4][3];
// TODO add your handling code here:
String s1=t1.getText();
System.out.println(" event 1");
String s2=t2.getText();
System.out.println(" event 2");
int k=Integer.parseInt(t3.getText());
String s3=""+k;
System.out.println(" event 3");
try{
// for(int i=0;i<=2;i++)
row[i][0]=s1;
row[i][1]=s2;
row[i][2]=s3;
i++;
}catch(Exception e){
e.printStackTrace();
table.setModel(new DefaultTableModel(row,title));
private void b2ActionPerformed(java.awt.event.ActionEvent evt) {
t1.setText("");
t2.setText("");
t3.setText("");
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new tabletest().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JButton b1;
private javax.swing.JButton b2;
private javax.swing.JLabel jLabel1;
private javax.swing.JLabel jLabel2;
private javax.swing.JPanel jPanel1;
private javax.swing.JLabel l1;
private javax.swing.JLabel l2;
private javax.swing.JLabel l3;
private javax.swing.JPanel p2;
private javax.swing.JScrollPane scp1;
private javax.swing.JTextField t1;
private javax.swing.JTextField t2;
private javax.swing.JTextField t3;
private javax.swing.JTable table;
// End of variables declaration
Mar 13, 2009 | Computers & Internet
Adhesives, Coatings & Sealants Logo
839 people viewed this question
Top Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
