Question about Radio Communications
Pl19c331044g how is this board installed?
    Master:
  • 623 Answers
What brand radio, what model?
Posted on Nov 05, 2013
How to turn off on-board video device ?
Go into bios and disable it if you can, if not remve the video card, update the OS and put the card back.
Sep 07, 2015 | Computers & Internet
I have a broaster fryer, and the pc board had burned out (possiblyt due to incorrect installation) need new board or can anyone fix it?
Replace the board. But first make sure the installation is correct. Then double check to see that the installation is correct.
Oct 05, 2013 | Broaster Pressure Fryer
Installed new board on rheem rtg74xn and it will not turn on or off , how do i get it to work i am technician asking before i get there what could it be!?
Most likely he did not program board with program chip....... Most of the boards i have had to replace, came unprogramed and had to program them thus the chip ...... I take setting off the old board and adjust the settings on the new board..... this really needs to be done by someone with experience working on the unit........
May 20, 2012 | Rheem Paloma Tankless Water Heaters...
I have a nvram error,950.31 after system board change on a t640.
950.30 through 950.60 EPROM mismatch failure
Warning: When replacing any one of the following components:
• Operator panel assembly (or upper front cover)
• System board assembly
• Interconnect card assembly
Only replace one component at a time. Replace the required component and perform a POR before replacing a
second component listed above. If this procedure is not followed, the printer will be rendered inoperable. Never
replace two or more of the components listed above without a POR after installing each one or the printer will be
Warning: Never install and remove components listed above as a method of troubleshooting components.
Once a component has been installed in a printer, it can not be used in another printer. It must be
returned to the manufacturer.
Note: Before proceeding with this service check, make sure you have the correct system board installed in the printer. The system board has a label with an board ID and barcode.
Replace the original system board with a new and not previously
installed system board. If the problem remains, contact the next level
of support.
Jun 30, 2011 | Lexmark T640 Laser Printer
I have an intex headphone, I have installed the realtek drivers and the headphone was working fine but I format the c drive and install windows again the same one windows xp sp3 and now after I installed...
*********** board installed sigmatel audio is being a original which supports system configuration. you cannot configure or change. So try to use sigmatel headphone.
Feb 25, 2011 | Computers & Internet
My mother board is Intel(R) Desktop Board D101GGC but after installing windows xp when i am trying to instal drivers i am getting the the error CURRENT SYSTEM IS NOT AN INTEL(R) DESKTOP BOARD. -...
You are installing the driver for the desktop board A044412A while your board is D101GGC so why are you installing that driver? Install your compatible driver.
Jan 11, 2011 | Intel D101GGC Motherboard
I have mercury board, i installed all drives but i cant install sound drive for that mercury board plz help me..
it it is p4 board then u need to format and reinstal ur os. immediately after insalling os intall sound drivers dont install anything else. after ur sound drives are installed then install other softwares...
Jan 28, 2010 | Computers & Internet
Audio driver
with some of the sound man drivers for motherboard chipsets it gives a BSOD error. blue screen of death. to fix this in the quikest manner i would install a pci sound card and install this one instead of the on board sound.
Mar 30, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Power running board failure
This is not really solving the problem, but my dealer told me that they could unplug the harness to keep the running boards in the down postion. The running boards have to be in the down position to make this happen.
Nov 18, 2008 | 2003 Mercury Mountaineer
Which sound card i need to instal
Here is a link to a diagram of the Optiplex GX 270 system board: http://support.dell.com/support/edocs/systems/opgx270/SM/EN/replbrd.htm
You need a sound card that has a PCI interface. On a Small Form-Factor board it goes into slot 10. On a Small Desktop system board it would install into the “riser board” which in turn is installed into slot 10. On a Small Mini-Tower system board the sound card would be installed into any available slot marked as 11.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Computers & Internet
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
