Question about Electrical Supplies
Sanli manual HI I HAVE A SANLI SLG2500 I CAN NOT GET IT TO GO CAN YOU PLS TELL ME WHAT SPARE PLUG IT USE
  • 54 Answers
SOURCE: Cant start the mower, already replaced spark plug,
Black smoke is unburnt fuel. Whether it is poor spark, bad gas, etc. Also make sure your oil level is not over full as this can cause it to blow by the rings and foul the gas.
Posted on Apr 28, 2010
SOURCE: where can i get a user guide for sanli lawn beetle ohv 350
I have a Lawn beetle ohv 350 lawn mower and it won't start. Is there any particular way or a secret way of starting it ?
Ben
Posted on Jan 08, 2011
SOURCE: i have lost manual for sanli brushcutter
Yeah i can't find mine as well
Posted on Feb 17, 2011
  • 2239 Answers
SOURCE: with the sanli bettle lawn
The blade retaining bolt is a normal right hand thread ( anti clockwise )
Posted on Apr 02, 2011
hunter19_46m
  • 7482 Answers
SOURCE: My Sanli Lazer Cut LCS 400 Lawnmower runs for a
Hi sabotomey...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Posted on Sep 25, 2011
I have a sanli mower 400...it keeps cutting out ...change plug ,clean flitter,drain petrol,checked hoses...still cutting out
There might be something floating around in the fuel bowl that blocks the jets or the float valve. Take the carburetor
apart and clean the jets and blow out all the passages with compressed air.
Nov 16, 2017 | Garden
Repair throttle control of sanli motor lawn mower
do u mean the cable , to much to explain on here but go on youtube you will find out how it is done on there good luck
Mar 07, 2015 | Garden
How to fix sanli whipper snipper start pull problem?
Hi, You should replace the spark plug. Most plugs die after 6 months of use. Also make sure that fuel mix is correct. Too much oil will make the motor run poor and stall. Good luck.
Aug 13, 2014 | Garden
Sanli mower
reply above is odds on on the right direct track. I got one of those same mowers, fuel tank had been filled with water, would only start with Aerostart ether blown into carb..the problem was the brass jet located inside carb housing underneath float-bowl retaining bolt.
if you are really cleaver and have a good tool kit, this can be removed without the awkward job of removing the carb from these mowers..a hexagonal short flat screwdriver bit can be inserted up inside that passage to engage that brass jet\'s slot, and turned with a smallsize ringspanner..it is a small brass screw-in part with a TINY hole drilled through it, so small that any piece of dirt or chip of rust can block it. Clear it carefully but AVOID PUTTING SOMETHING BIGGER THAN THAT TINY HOLE THROUGH IT..YOU DO NOT WANT TO REAM OUT THAT HOLE AND CHANGE IT\'S SIZE IT WILL WRECK THE MOWER\'S RUN-MIXTURE SETTING. carefully replace it as you removed it without overtightening it.
If it was blocked and you have successfully cleared it and replaced it, chances are mower is now operational.
Apr 29, 2014 | Garden
I have a Sanli Laser Cut 400 - manual is misplaced/lost - bought July 2010. We have had lots of wet weather. It has always started easily. It started the other day but peeted out after about 3 mins...
Make sure the fuel tap lever is over to the LEFT as you look at it, should point straight out. Lying flat to the right is OFF - at least on mine. The pictures in the manual can be a bit confusing.
Dec 18, 2010 | Garden
I have a sanli mulcher lawnmower about 3years old, always ervicedand looked after. last few uses its been gutless. today it was running but stopped. when I went to restart it, it made ratchetting sounds,...
Never heard of a sanli. If the engine is backfiring, indeed it could be out of time. One sure way to check if it is out, is to see if the flywheel key is sheared.
Please vote on this solution.
Sep 05, 2010 | Garden
Cant start the mower, already replaced spark plug, airfilter is clean. When starting a small black cloud comes out so think it has to do with a oil filter, lost manual so cannot check, need to find a copy...
Apr 26, 2010 | Garden
I have lost manual for sanli brushcutter
Mar 04, 2010 | Garden
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
