Question about Maytag Neptune FAV6800AW Top Load Washer
All buttons cause machine to beep
I put clothes in the washer and I close the lid. I push a button to make a change like the temperature it just beeps. I push dampness and the machine starts. Most of the buttons just beep and do nothing to change the lights. Each press of a button causes the machine to beep three times really fast and makes no change on the display. No error codes are displayed. Please help.
  • 291 Answers
Trying unplugging for 20 minutes maybe you can reset it.
Posted on Aug 29, 2007
SOURCE:
New Control Panel instald all it does now is beep open lid stop beeping close lid nothing happens lights stay on help please
It is important to set the size switch setting into the Motor Controller's memory whenever a replacement Motor Controller and or Display Module is fitted
To set the size switch turn the power on at the wall and off at the machine. Press and hold the TEMPERATURE UP button then press the POWER button. SmartDrive will give 4 short beeps and the pattern of LEDs will change.
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for (8.0kg) (650mm wide). • Press POWER to exit this mode.
If this doesn't work let me know
Jul 16, 2015 | Fisher and Paykel GWL11 Top Load Washer
My cabrio washer won't unlock lid, dU error, can see a piece of clothing that is stuck through the glass lid, what do I do?
Sounds like the clothing is creating too much pressure on the door and giving you a door lock error. Unplug the wash machine and wait a few minutes, then, while pushing in on the door to overcome the pressure caused by the stuck article of clothing, have someone plug the unit back in. If you've done it right and pushed hard enough, the latch should unlatch.
Dec 29, 2014 | Washing Machines
I'm having problem with my front loader it is in a pause mode it stop working when i try to push the start button it just makes a beep-beep sound while trying to push buttons the door is close,it does...
Hi
It looks like you have a problem with the locking mechanism of the door.
This is a safety feature to prevent injury while the machine is running. First of all check the power supply and if found OK then you have to concentrate on the door. If the door is not closed properly or the device is malfunctioning then the machine will never switch on, no matter what you try.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 27, 2011 | Frigidaire ATF6000ES Front Load Washer
Loses power in spin cycle
First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
Apr 03, 2010 | Kenmore HE2 Plus Front Load Washer
Is there a reset button for my Whirlpool Cabrio Washer? Every time I start a load of laundry to wash, the washer puts the cycle on pause at least 5 times. I have to hit start, wait for it to beep, hit...
Check the lid switch and its actuator on the lid. The pause you're getting is likely an open lid sensed by the washer control. Also try to push and pull the inner tub up and down a few times - if I remember correctly these washers have a floating basket, which engages the gears when there is enough weight inside. If there is not enough clothes it may not wash correctly (I don't remember exactly, but try it anyway, what do you have to loose? ;) ).
Nov 02, 2009 | Washing Machines
Started the washer and then it stopped and machine
Try pushing the basket to the back so you can reach the lid switch housing - you should be able to re-align it by hand.
If that is impossible, that means the lid switch plastic housing broke loose and needs to be replaced.
I would need a model # so I can help you with instructions.
Aug 18, 2009 | Maytag Washing Machines
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Lid Lock light stays on
You are eligible for a refund. TAKE IT ! ! This should be a learning experience.Since when did the consumer have to be come the repairman WHEN ITS UNDER WARRANTY ,C,MON NOW!!!
Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
709 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
