Question about Motorola Televison & Video
8888 code and all the lights light up
I have a Motorola DCX 3501-M this has happened to my other cable box once ir twice tooo. the cable supplier is charter, what happens is the box shuts down all the lights turn on an 8888 code shows then it reboots and reprograms. it continues any series recordings and goes back to normal. the other box is a little larger then the 3501-m it has the same design and its also a dcx but a different model and deffinently has less hdd space.
5 Suggested Answers
SOURCE: Sometimes wireles goes down unexpectly
OK often it's the XP Zero Configuration service, try disabling that and it may be better... also get the latest driver updates... Often just to disable and re-enable the wifi adapter sometimes in network connections, brings it back without a reboot too.
Posted on Jul 18, 2007
  • 324 Answers
SOURCE: Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Posted on Nov 10, 2007
MobyMech
  • 106 Answers
SOURCE: 5.9 DIESEL ENGINE CUTS OFF WHEN DRIVING
Hi
From what I can gather, the engine cuts out and then the check engine light comes on, not the other way around, check engine light and then cut out?
If you switch on the ignition but do not start the engine, you will see that the check engine light is on. It won't go out until you start the engine.
When the engine cuts out, it is just as though you have switched on the ignition without starting the engine, the key is in the exact same position, and therefor the check engine light comes on purely and simply because the engine isn't running, not because it has sensed a problem, hence you have no fault codes, its perfectly normal.
If, however, the light comes on then the engine cuts out, then the reason for the lack of codes could be a short term electrical failure. If the power to the ECM were briefly cut then the codes would be erased immediately, but this would have to be a complete failure because there is a KAM (Keep Alive Memory) wire, which supplies permanent power to the ECM if I'm not mistaken. A good candidate for a complete failure is a bad main ground cable (loose or broken).
Wiring problems a just the worst ever to trace.
Just a thought to hopefully point you in the right direction.
Very best regards
Geordie
Posted on Jun 10, 2008
SOURCE: Verizon FIOS Motorola 6200-2 HD box remote freezes
i'm a verizon employee currently working at a customer's house. just swapped out 3rd 6200 stb, the channels will seemingly change on their own(scrolling) after pressing the remote just a few times. the root of the problem is that the remote is not responding to the stb in the first place properly. all i can figure is that there is some type of ir interference. i've placed the remote 1" from the stb and the same problem exists. it's not the box and the remote is brand new, tried 3 remotes as well. there is something going on in the atmosphere around the box - in or outside the custmer's house. they were on vacation and when they came back this is the trouble they were having. i don't have an answer, just some type of possibilities. there is a power transformer outside on a pole approx. 100' from the house and we had bad storm related issues in the past week. i know it's a stretch, but you never know. could be surround sound/ stereo equipment generating some kind of field??????????? good luck.
Posted on Aug 10, 2008
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Jan 21, 2016 | RCA Televison & Video
3520 manuals
Contact Arris Support
ARRIS
Mark
Motorola Support
Jun 23, 2014 | Motorola Televison & Video
Motorola dcx 700 no power since a slight power
It's possible that the box is dead and need's to be replaced. One thing you can try is rebooting the box by unplugging the power cord and then plugging it back in. You can also try plugging it into a different outlet. Are you sure it's the box that's dead and not the tv?
Oct 14, 2013 | Televison & Video
I have a motorola dcx 3200 cable box and its asking for command code please help
Codes to check with motorola are 035,048,029,085,092. If you wish to get more codes and other details, check this link.
Feb 15, 2013 | Televison & Video
Hi, I have a problem finding a code for my motorola DCX3200 with my universal remote control(cox.) All the other televisions in the house worked, but I can't get this one to respond at all. I have an LCD...
Here is the user guide for the Motorola DCX3200 in PDF format just in case you need it.
Now then here are some Codes for your Cox Universal remote. I understand you have tried some already but just in case you missed any.
Samsung 0060, 0030, 0178, 0019, 0056, 0032
Also give this a try.
  1. Turn on the TV, VCR, DVD, or entertainment center that you want the remote control to control.
  2. On the remote control, press the appropriate mode button for the device once.
    Television TV
    Stereo amplifier or receiver AUX
    DVD, PVR, VCR DVD
  3. Press and hold the SETUP button until the selected mode button blinks twice, then release the SETUP button.
  4. Using the number keys, enter 9 - 9 - 1.
    Result: The selected mode button blinks twice.
  5. Aim the remote control at the device, and then press the POWER button once.
  6. Press the CH+ (or CH-) button one or more times until the device turns off.
    Notes:
    In search mode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
    If, while pressing the CH+ button, you inadvertently pass the code, press the CH- button one or more times until the TV turns on.
  7. Press the SETUP button once to lock in the code.
  8. To search for codes for other devices, repeat steps 1 through 7.
Hope this helps, give me thumbs please!
Aug 23, 2010 | Televison & Video
Need the code for the charter remote for my vizio
For example, to search for a code for your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
  3. Enter 9 9 1. The TV key blinks twice.
  4. Press 1 (the device code digit for your TV). The TV key blinks twice. Aim the remote control at the TV and press POWER once.
  5. Press and release the CH+ key continuously, then stop when the TV turns off.
NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
  1. Press POWER. The TVshould turn on, then press SET UP to lock in the code.
NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
Jan 12, 2010 | Vizio VO47L 47 in. LCD TV
Need remote code for LC420SS8
SEARCHING FOR YOUR CODE
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
Turn on your TV.
On the remote control, press TV once. Then press and hold Setup until the key blinks twice, then release Setup.
Enter 9 - 9 - 1- 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device.
Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
Press Setup once to lock in the code. The TV key will blink twice.
To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are searching for.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Reset
using your remote hit replay-list-live tv 3 times each it will shut of reset then hit list & will read 0
Mar 28, 2008 | Arris DCT6200 DTV Receiver
Charter cable box
Could not find box on list but here is your product manual:
http://www.ofausa.com/remote_manual/CTGAE3P%203021%20anual%20booklet.pdf
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes:
Dec 11, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
930 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
