How do I empty the water tank whirlpool amb 761
Zanussi ZDC8202P-WH. Only 10 days old. It stops halfway through the cycle with the 'water tank full' indicator coming on, but tank doesn't need emptying. It is in properly.
Return it back to the place of purchase and buy a different brand of dryer. Try Whirlpool or Sears Kenmore. You should have much better luck with these name brands.
Dec 01, 2015 | Zanussi Dryers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Our toilet Kohler 4634AA will not flush. Changed the flapper, followed the directions, etc. but still won't.flush properly...runs runs runs.
If the tank is filling with water to the line level, and the flapper raises, and stays raised until tank is almost empty, when flushed then it must be a clogged line. Try a plunger (toilet snake) and/or call a plumber.
Sep 04, 2011 | Home
My dad has a portable Whirlpool ac unit. for the last couple of days it stops running and needs to have water emptied. Can I fix this for him?
you would need to drill the pan ad install a drain hose on or around the bottom of the water tank, you will need a place for that water to drain to, there is auto drain pumps that are used on under cabinet ice machines also, but $$$ .. hope i was of help.. jay
Jul 25, 2011 | Whirlpool ACP102PS Portable Air...
The tank doesnt fill up by itself after flushing. I have to manually lift the bar to start water. Then when the water is running the floating thing doesnt rise and the water empties again.
The floating thing is most likely filled with water, if the unit is old replace everything inside the tank you will be better off if you do not wish to do that just replace the floaty thing. Good Luck....
Nov 15, 2010 | Home
I HAVE WATER COLLECTING IN THE BOTTOM OF MY WHIRLPOOL FRIDGE
Must move the fridge forward to see if the water leak is an overflow from the defrost overflow tankwhich is placed below the rear bottom.
So if this tank is overflowing empty and chek.
if not it can be a leak from the pipe that leads to the tank .
You will have to checck while the frridge works to finalise
Sep 26, 2010 | Whirlpool Refrigerators
We have a newer Whirlpool Cabrio washer and no matter how many clothes we put into it we always get a ol error.
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My dehumidifyer won't continuously run
HI,
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care
Aug 11, 2010 | Whirlpool Dehumidifiers
Compressor doesent run, fan runs
brand new hunter humidifier was working for about a week now there's no water in tank it has all leaked to the floor tank is empty
Apr 03, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Whirlpool model gsl9365ez2 / doesn't agitate or spin
Check your drive coupler, its located between the motor and transmission
Mar 19, 2009 | Whirlpool Washing Machines
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
