Posiflex PP5600 manual
Need programming example code to open posiflex cash drawer
ohms
  • 1879 Answers
SOURCE: cash drawer
Greetings,
From the computer (application to be exact), you send a signal to the printer to kick the drawer open but is there a confirmation signal from the printer going back to the computer that it successfully opened the drawer (not just successfully carried-out the command) ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 19, 2008
SOURCE: Cash Drawer Command
The cashdrawer is SERIAL, you'll need to connect it to a COM port. The
software you're using has to be capable of sending data to the COM port
the cashdrawer is connected to when the cashdrawer needs to be opened.
From the site you mentioned:
Be sure drawer lock is not engaged.
Exit your system to a DOS prompt. Type the following commands (substitute
the correct com port for com1):
c:\>mode com1:300,n,8,1
c:\>echo "000000000000000000000">com1
The cash drawer should open.
About the cashdrawer RJ11 connection on the printer: You can connect any
solenoid driven cashdrawer to this port. The port uses pin 2 and 4 for
the voltage output, which is normally 24V on Epson receipt printers.
Sending a specific ESC character (every POS software should be capable of
doing this) to the printer will be recognized by the printer and the
printer puts 24V on the 2 pins mentioned for 300ms and voila, the drawer
opens.
Posted on Jul 31, 2008
SOURCE: posiflex 7000 p
driver for pp-700011 for windows xp
Posted on Aug 08, 2008
SOURCE: opening drawer through star sp200
code for star printer sp200 open drawer code ( tested and works ) 27,7,11,55,7
Posted on Oct 25, 2008
Basti
  • 1447 Answers
SOURCE: I have an epson tm
Hi!
Are you using the Epson TM-T90 driver? When you go to printer settings through Printers and Faxes there is an option to Open Drawer after or at the Beginning of the transaction.
One other way to check if you have the correct commands for it is by checking on printers Manual and Technical documents of it where you can get online. Click HERE. Register and wait for an Email for Username and password.
Hope this helps.
Posted on Jan 05, 2011
When pressing the department key, the cash drawer opens after each transaction, is there a way to stop this?
You have programmed SICS or single item cash sale. Check the programming for that department and set SICS to off
Jul 21, 2015 | Samsung Retail Supplies
How can I get a replacement key for the lock on the drawer?
cash register drawer keys usually can only be purchased from drawer manufacturers...it all depends on who makes it, mmf casio apg samsung etc
Oct 09, 2014 | Royal Cash Register 500dx
Casio s400 e35
Change amount exceeds preset limit.
Someone has programmed a limit on payments (usually on the cash button). Try paying by a different method (check, credit) and see if it opens the drawer. If so, you will need to re-program the cash button for no change limit. There is a code to do this in your manual. I don't have any info for programming this model. If you don't have a manual, one of the users has the SE-S400 Casio manual here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S400_Operation_and_Programming_manual.html
Apr 03, 2014 | Casio Parts Cash Register PC Desktop
I have a Samsung SER 6500 II cash register is locked on the error code ERR PRT. I have checked the ribbon and receipt feed area. Nothing blocking it...I've done an intial clear to no avail.
Sounds like you have printer failure. Have you tried flicking the lever under the drawer between the back two feet to open it?
If anyone is having problems with Programming on the Samsung SER-6500II cash register, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Samsung3.php
Sep 03, 2012 | Casio Parts Cash Register PC Desktop
PP8000B printer just prints garbage..and Cash drawer doesn't open have tried the O POS manager , tried almost everything .. Any suggestions welcome...HELP
Every POS software has commands that opens the cash drawer and prints the ticket. It also controls how long the receipt ticket is, if it prints in color. Then there are two types of cables that communicate between the cash drawer and the printer to pop the drawer. Then there are dip switches in the printer that change how the printer operates according to the software. When it prints garbage, the driver that comes from the POS software is not synced with the printer. Sorry you asked. Call the POS Software company.
Apr 10, 2011 | Posiflex PP7000 Printer
I have a client with a Posiflex system running PC America Restaurant Pro Express 9.5. This was a used system which I purchased from a discount house. I set it up and delivered it to the client a week...
You could try reloading RPE. It only takes a few minutes and could correct the problem. You would not lose any settings because they are stored in the database. Be sure to backup database before you do this.
But why aren't you running it thru the receipt printer. Much more reliable.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Jan 08, 2011 | Pc America Restaurant Pro Express
Posiflex cash drawer CR 3100 wiring for 6 pin phone plug
If you have the following pairs of wiring:
Blue/White - White Blue
Orange/White - White/Orange
Green/White - White/Green
Then the pairing starts as follows:
Pin 3 - Blue/White
Pin 4 - White/Blue
Pin 2 -White/Orange
Pin 5 - Orange/White
Pin 1 - Green/White
Pin 6 - White/Green
If your wiring has different colors, please let me know and I get you the correct wiring plan.
Don
May 10, 2009 | Posiflex AURA 7000 Matrix Printer
How do you open the drawer on a Samsung er-4900 cash register?
Under machine usually a hole with a release switch. Or put in Z position and hit amount tend totals key. May run and open drawer..
Apr 23, 2009 | Office Equipment & Supplies
Posiflex 7000 p
Jun 30, 2008 | Posiflex AURA 7000 Matrix Printer
Ok
please type the following line as i am writing here to your commad prompt:
MODE COM1: 96, N, 8, 1
and then printer
I am sure it will work.
Thanks
Iqbal
Mar 12, 2008 | Computers & Internet
26 people viewed this question
k24674
jasbo
jasbo
