Question about Electronics - Others
What is UV light? - Electronics - Others
It will be better if you can give more exact and particular question. UV light is the short form for ''Ultra Violet Light". It is an invisible light for normal eye. It has very short wavelength. You cannot see that UV ray by normal eye. But you can see it through the digital camera.
Posted on Jul 16, 2013
    Problem Solver:
  • 15 Answers
UV (ultraviolet) light is, according to Wikipedia, "electromagnetic radiation with a wavelength shorter than that of visible light, but longer than X-rays"
"It is so-named because the spectrum consists of electromagnetic waves with frequencies higher than those that humans identify as the color violet. These frequencies are invisible to humans, but visible to a number of insects and birds." (wikipedia)
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
How do i go about replacing the uv light
obtain proper replacement bulb
shut down entire filter for a moment before unscrewing the top locking ring off Uv filter (left turn) lift top off set asside
using a soft clean rag retract uv tube from its cylinder holder inside , remove power connector from tube end (you should have already removed all power from converter box) with extremely clean rag handle new tube ( allow no forign material to touch outside of tube ) reinsert power connector onto new tube (same way it came off old one) then reinsert tube into holder sleeve , route power cord to proper places away from lid , replace lid and install lock ring back with enough force to ensure a leak proof seal , re start pump ck for leaks if none found then restart power converter for Uv filter
Jun 05, 2015 | Sunterra 300207 Pond UV BioFilter 2000...
How do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
What is UV index?
The UV index is how ultra violet is measured, the index ranges from 0-11 with 0 being the lowest danger of the UV rays and 11 being the highest danger of exposure to UV.
Sep 17, 2013 | Measuring Tools & Sensors
Are black lights bad ultraviolet light?
Black lights are UVA waves, they are considered the least harmful of UV. But like the bad UV that you hear about extended exposure to UVA rays can lead to skin disease and cancers.
Under what circumstances would i ever need a uv light meter?
uv light is undetectable to the human eye but it can be damaging. if you detect a high amount of uv light, you can take steps to redirect or block it
Jan 28, 2013 | Measuring Tools & Sensors
When you're choosing sunglasses, does UV protection matter?
Yes, ultraviolet (UV) eye protection matters. UV radiation from the sun can damage not only the skin of your eyelid but also the cornea, lens and other parts of the eye. UV exposure also contributes to the development of certain types of cataracts.
When you're choosing sunglasses, look for UV-protection details on product labels. Choose sunglasses that block 99 to 100 percent of both UVA and UVB rays. Skip sunglasses that are labeled "cosmetic" and those that don't offer details on UV protection. Opt for larger lenses rather than smaller lenses - or, better yet, the wraparound variety.
Nov 07, 2010 | Clothing Accessories
5W pondmaster UV clarifier, how to tell if it's working
You can tell if the UV light is on by feeling the case surrounding the light. If it's warm the light is on.
Hope that helps,
RSMITH972278
Oct 12, 2009 | Pondmaster UV Clarifer
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Electronics - Others Logo
512 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
