Question about Proview PL926WBi 19" LCD Monitor
Wavy lines, goes black during video games.
The screen has a lot of flickery wavy lines that appear when just running typical applications, internet explorer, etc. When playing a video game, even at the suggested 1440x900 resolution, the video goes black (used to come back and go out again quickly, now doesn't come back at all). It does come back if the video game is minimized or closed using alt-tab or w/e. The odd thing is, even when a video game is ran in windowed mode, when the video comes back it comes back as if it's just switched video modes (it auto adjusts itself to the 'new' mode). Video card temp is normal, the monitor behaves the same way on multiple machines, and a different monitor works properly without flaw on the original machine. Thanks in advance, Mythics
  • Mythics Aug 28, 2007
    The monitor supports 60-75mhz, and I've tried multiple resolutions and multiple refresh rates. It's also not a single game that causes the issue, but any game (that I have at least).
    The refresh rate shouldn't be an issue considering the same effect happens even when the game is ran in windowed mode as I previously stated (refresh rates only change when a game is taken to full-screen mode).
    Games I have known to work in the past under their preset resolutions/refresh rates are causing the same issues.
    Sergeant:
  • 279 Answers
It sounds to me like the monitor's refresh rate is too low to support your current settings, and the demands of the game. Have you tried adjusting the refresh rate? If I'm right, you should be able to fix the wavy lines that way. I'm not sure how much control over the refresh rate the game takes, but if you can fix the wavy lines and the game still doesn't work, I think you're not likely to get the game to work on this monitor.
Posted on Aug 28, 2007
  • Anonymous Aug 29, 2007
    My mistake. I was thinking, since you said it was coming back when a game was running in windowed mode, that the game in question was, for some reason, changing your video settings even in windowed mode. I have seen that happen with a handful of games. I didn't realize you meant it happened with every game.
    The only other thing I could suggest then is to update your monitor drivers. I found some drivers for that model on driverguide.
    http://members.driverguide.com/driver/de...
    You do have to sign up to download their drivers, but it's a painless process and they don't spam you. Actually, it's a very good site, one of the first places I go if I need a driver for anything.
    If that doesn't help, then I'm stumped. I suppose it could be a fault with the monitor itself, though if it is there's not really much I can do about that anyway.
6ya staff
SOURCE:
Wavy snow lines on samsung
are those lines appear in the screen either you hooked up a source like a dvd player and also during watching tv channel?.if so, locate the t-con board which is mounted covered with metal shield. tried first with re seating the LVDS cable connected to the board to fix loose connection, remove and then re attached to the connector terminal.hope this can help good luck.
Sep 07, 2012 | Samsung Televison & Video
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
PS3 wo't start up. I turn it on wavy sony ps3
Your hard drive is bad. you need to replace it.
Sep 02, 2009 | Sony Playstation 3 (PS3) Console
When I switch my ps3 on, there are just wavy lines across the middle of the screen, the icons do not appear and games will not play
If you have componite connetion and have played in hdmi than you need to switch the connection back and you will see the screen. Set it to auto detect, go to video settings
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
When I turn on my ps3, the initial music plays and the wavy bar comes up with the words "playstation 3" like normal. It then does nothing. The wavy bar stays on the screen and nothing happens. The color...
i had the same problem, i reset the PlayStation 3 video mode (when playstation is off hold the start button till you hear the second beep) and had to hook it up with the A/C cables and it got it working for me
Jun 14, 2009 | Sony PlayStation® 3 (80GB) Console
Wavy black lines
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem.
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
I which on my ps3 is loads up but online the wavy lines appear
That's not too hard to fix.
Check out my guide here:
Pay attention to #3.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Wavy lines across the digital screen of DSC-V1
Can u mail me 1 photo at [email protected] to understand what exactly happening with your camera?
May 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
PS3 video output on SD tv is wavy with discoloration and black line
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Proview PL926WBi 19" LCD Monitor Logo
197 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
