Insignia tv nsl46x10a
Tv turn on and picture has gren vertical lines and it is blurry
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
  • 718 Answers
SOURCE: insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Posted on Feb 23, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
ripleymojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
INSIGNIA NS-LCD26A Model tv powers on with rainbow vertical line/blurry/cloudy/greyish etc. The sound Comes, SOUND OK.Capacitors on power module look fine,no bulging, but not checked with multimeter. Any...
if you check with multimeter, you know all worked fine, you need code programing of the tv, this code is for reconfiguring your tv, search by model, by device and brand, oh you need the remote control original, for solve this problem...
because the problem is programing electronic, the tv have a cpu and have a program, who can solve is expert electronic....
Mar 07, 2010 | Insignia LCDTV26 26 in. Television
Our Insignia TV has a vertical line right in the center, and the picture to the right of the line has a "lava lamp" look...sorta cartoon coloring. Looks this way with a DVD or satelite. Suggestions?
Are there any speakers directly beside/above or below the t.v? If so remove them away from the tv. The magnets in the speakers will distort your picture.
Dec 09, 2009 | Insignia IS-LCDTV32 32 in. Television
TV doesn't turn on. Insignia 32LCD
check the power supply boards apply fresh solder also apply fresh solder to inverter board. scan budged capacitors from secondary power supply.
Jun 04, 2009 | Insignia IS-LCDTV32 32 in. Television
Lines with occassional picture
This is a problem with the main board. This board does the signal processing and sound audio processing. The problem may just be some over expanded solder connections that have lost the ability to stay in contact with the board. It could also be a problem with some component failure. If this unit is still under warranty call the Insignia customer support at this telephone number 1-877-467-4289. Give them the model number of you television and they will tell you how to get service for it. The Insignia customer support website is www.insignia-products.com. Go to the customer support and ask them for help with your model of television.I hope this information helps you with your problem.
May 25, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia ns32lcd no picture just lots of vertical colored lines
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
