Question about Drills
My craftsman fast charger 7.2v-24v says by way of light that battery is defective when in fact its the charger itself
5 Suggested Answers
emissionwiz
  • 80407 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
  • 145 Answers
SOURCE: 24v sds.no lights on charger but making humming
If it is out of warranty open it up and check the fuse inside. This has happened to me several times with several brands, and it has always been the fuse. They are usually replaceable at Radio Shack or the Auto Parts Store.
Hope this helps!
Jim
Posted on Aug 05, 2009
SOURCE: My new Black Max 24v drill charger will not charge the battery
Battery charger for electric drill Agojama 240v- 50HZ
22v_ 400mA 14.OVA
Posted on Jun 05, 2013
  • 6 Answers
Cordless Drill Charger for Dewalt 7.2V 9.6V 12V 14.4V 18V Battery
Drill Charger for DEWALT 7 2V to 24V Ni Cd Ni MH Li ion Battery UK
Posted on Mar 18, 2015
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
Craftsman fast charger
run all 3 batteries down to full dead then fully recharge. some times this can help
Nov 27, 2013 | Garden
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
I have a craftsman drill charger and the red light comes on for a few seconds hen oes off is it the charger or the battery or both?
The problem could be either the result of a defective charger or a defective battery; however, I would put my money on the battery being defective.
Jan 09, 2011 | Craftsman Garden
I fitted new batterys, now the joystick is reading low battery but no responce from the joystick.the batterys are wired red to red and black to black does the chair turn this to 24v itself, theres no...
Will you don't say what chair you have and they can all be wired differently. Look under the shroud that covers your batteries and see if there isn't a wiring diagram there. If you let me know the brand ie: Pride Jazzy, Invacare M51 etc. I can give you the proper wiring for the batteries. Now you also didn't say if you charged the batteries after you installed them. Remember always charge before use. Just because they are new doesn't mean they are charged (in fact they could have sat on the shelf for a while). Make sure that they are no older than 4 months old even new batteries can be bad. Charge these puppies overnite. When you plug in the charger you should see a red and yellow light after charging overnite you should see a red and green light( indicating full charge) If when you plug the charger in you get a red and green light then something isn't wired correctly. Hope this helps
Oct 27, 2010 | Health & Beauty
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Do not start when start button is pressed. Seems power adapter K30266 is defective. Output should be 24V, but I get only 7.2V.
power adapter is definitely defective if it only has 7.2 volts on it output. check if you have plugged it in the correct voltage!
May 21, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Drills Logo
44 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
