Contacting JVC for Factory Values
I inquired recently if and where I could locate the 'calibration settings' for this particular model of JVC television, AV32D501. I was told to contact JVC for the 'factory values'. Actually it was Bobby Caesar who has steered me in this direction after I posted my question on Fixya. My question is do you know or can anyone provide me with either the contact number or email address for JVC in order to request the factory values for my JVC TV? Thank you. Regards, Charles
    Champion:
  • 247 Answers
Ok charles here u go telephone 1800 537 5722 call this jvc service number u still need a tech do not try to do the adjusts yourself cos u may damge the system completely if u want the manual type in the net searches www.manualslib.com and in its page type the model and type and ask for the manual u will get the factory values from the jvc service center charles
Posted on Jul 18, 2013
MikeNJ1964
  • 398 Answers
SOURCE: Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Posted on Aug 29, 2007
Shuttle83
  • 1139 Answers
SOURCE: what is monoscope signal and ntsc full mode
Indian pattern
Posted on Oct 14, 2007
Slinteriors
  • 8617 Answers
SOURCE: PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Posted on Jul 19, 2008
SOURCE: CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Posted on Oct 17, 2008
jomabug76
  • 1148 Answers
SOURCE: Hitachi Rear Projection TV with Pink Tint
SEE IF IT HAS A COLOR CONVERGENCE IN THE MENU ,,TRY THAT
Posted on May 15, 2009
Printout not align and faults indicates led lit up
The Media Sensor is not seeing the labels or is not configured for these labels. Check Media Sensor position and settings. The Fixed Sensor models have a small window for the sensor at the bottom of the printer, about 3/8" to the right of the left side. If the printer has a movable sensor, the typical position is either 1" to the right of the left edge of the labels, or in the center of the labels. Typical media sensor setting is "Gap Mode". Another common issue is that the sensor might have a piece of label or something stuck to it, covering the lens. Finally, there is a possibility that the reflectivity threshold may need to be recalibrated (see below). This can be difficult, although there are instructions in the Operator's Manual. If physical position/clear view of labels by sensor doesn't seem to be the issue, an easier way to deal with settings issues might be to Restore to Factory Defaults (see below).
Datamax E-Class Auto Media Calibration Procedure:
The 'Auto Media Calibration Procedure' allows the operator to
automatically obtain the optimum (TOF Low and TOF Delta) values for
a particular media. These values are useful for media that continues to
have troubles after Media Sensor has been manually calibrated (usually
preprinted media). This operation feeds 10 inches of media using the
current Media Sensor Calibration setting and calculates the TOF Delta
and TOF Low values to be used. Upon completion the printer will exit
back to 'Calibration Mode' flashing the PAUSED light if successful or
the FAULT light if not successful.
Note: Before calibrating, be sure the media sensor is set for the
appropriate media type, see section 4.4.2, also be sure the
printhead is latched down and the cover is closed.
To perform the Auto Media Calibration complete the following steps:
1. Load the desired media.
2. Hold the button while powering up the printer. Continue to hold
the button until the PAUSED light turns off then release.
3. Next press the button, (the printer will now calibrate to the
media)
4. The PAUSED light will flash 5 times to indicate a successful
calibration. The FAULT light will flash 3 times to indicate an
unsuccessful calibration.
Note: If you wish to discard your changes and revert back to the
previous calibration simply turn off the printer before Step 5.
5. Now you can save your changes and resume by again
pressing the + buttons simultaneously.
Datamax E-Class Reset to Factory Defaults Procedure:
With the printer off, press and hold the F1, F2, and F3 buttons while
turning the printer on. Continue to hold the buttons down until the
PAUSED light turns off. The printer will now be set to the 'Factory
Defaults'.
Jul 22, 2014 | Datamax DMX E4203 Printer
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
Calibration Settings for JVC TV Model AV32D501
no u will need the factory values of that model of tv to be able to balance them check with jvc for the values u will have to access the ez menu where u will balance the offset as given in the factory values do not do anything u did not go for cos u will distort other parameters u will need a tech
Jul 14, 2013 | JVC AV-32D501 32" TV
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
I have a samsung model sgh-a877 and the touch screen isn't working right. How can I do a factory reset?
To reset the handset, to the factory default settings, follow the steps below:
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Reset Settings
  4. Press on any of the following to check their boxes:
    • All: Sound Profiles, Display & Light, Phone and Alarm settings will be returned to default values
    • Sound Profiles: Only sound profile settings will be returned to default values
    • Display and Light: Only display settings will be returned to default values
    • Phone: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
  5. Press Reset
  6. Enter the password default password is "0000", then press OK
  7. If prompted, Enter the password again to confirm then press OK
  8. Press Yes to Reset the handset's settings to the factory defaults
One note tho. if i'm not mistaken you will lose ALL data in the phone. if it's been unlocked you will have to unlock it again.
this is refered to as a hard reset. soft reset would be just to take the battery out for a few minutes. that way you would keep your data
Jun 15, 2011 | Samsung Cell Phones
I have an sgh-a877, impression, and I can't find a reset button. Is there one on this phone?
  2. Press Settings
  5. Press Reset
May 25, 2011 | Samsung Cell Phones
How to do a factory reset on a zebra stripe printer?
Apr 23, 2011 | Zebra Stripe S600 Thermal Label Printer
I need the codes to unlock my j.v.c blue ray nx-db3. Thank you
Turn on JVC TV, simultaneously press DISPLAY and VIDEO STATUS in JVC remote control .
To select items, press MENU UP / DOWN (upload / download). To change values MENU LEFT / RIGHT (left / right). To exit factory mode press EXIT.
Write down all settings before change all TV system value seting.
Feb 28, 2011 | JVC Televison & Video
Blue light flashes
it is most likely the convergence panel. do your speakers make a thumping sound? if not, disregard this solution. change the stk392-110 convergence amps located behind the front cover on the convergence board. also check the resistors, it seems like they always take out two or more resistors. make sure all of your solder connections are good and none of them are touching. also, when you get the set back on you will need to manually adjust the convergence from the menu. you will need the factory remote. if you find bad resistors, the values are on them, but if you need the values and wattage, then use this page:
http://home.comcast.net/~dande76530/ConvergenceOutSchematiics.pdf
hope this helps you.
Feb 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
