Question about Cell Phones
Compaq crt monitor powerbutoom blicks and doesnot display
Compaq pe1110
Benimur
  • 6966 Answers
SOURCE: dim compaq s510 crt colored monitor
Hi, If you are comfortable working with tools, down to component level and know how to work around EHV areas, then it is possible to increase the brightness of any monitor including the Compaq S510. Make sure that the unit is unplug, Open the back cover and locate the FBT. You have to run/power on/attach a running PC to the unit with the cover off. Extreme care must be exercised. If you are not sure, you're better off asking a qualified service professional to do the adjustment. There two plastic slotted adjustables, focus & screen. Adjusting the screen changes the screen voltage going to the CRT. This will make the display go very dark or overly too bright. Adjust to your preference (not necessarily technically correct) The focus may also be adjusted this way. You have to run the unit with the back cover open for a couple of minutes to stabilize the voltages and the heater/CRT/ Adjust after a couple of minutes if necessary. In other monitors, there is a trimpot (small variable resistor) the adjusts the sub-bright. Further improvement maybe achieved by adding a 100uF/250V capacitor across the supply of the 70+VDC of the 3 gun transistors. If you are sure how to go about this, it is best to consult or seek the services of a qualified TV technician who can either show where and how or do the job himself. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 31, 2007
worldvet
  • 859 Answers
SOURCE: Compaq 1720 Monitor
You may need an adapter plug. They come with new monitors so ask around to see if anyone has one you can borrow.
Posted on May 11, 2008
ceezer
  • 20 Answers
SOURCE: how to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Posted on Jul 08, 2008
SOURCE: Schematic diagram
plz send me philips lcd monitor diagram power supply model 150B
thanks
regards
asif mansouri
Posted on Jan 03, 2009
gymowner
  • 679 Answers
SOURCE: compaq evo d500 doesnot connect to internet through DSL
is the desktop connecting wirelesslly like the laptop? What kind of router are u uaing, if you are ccnnecting via a wired connection, you need to rt click on my network, "on the desktop"go to properties, add a new connection, and let the wizard walk you through the setup, it just isn't set up right for the network, you can also use the one that says connect to a home network.
Posted on Mar 17, 2009
Compaq FS 7600 - display - CRT - 17" driver
click start control panel you will see thre options change theme change desktop background and adjust screen resolution then select resolution from the drop down list you can adjust to your preffered settings 1024x 768 is usually recomended (you have not stated your problem)
hope this helps
Sep 22, 2011 | HP Compaq FS7600 17" CRT Monitor
I have A Compaq monitor,edited
omg an antique monitor
a relic CRT monitor?????really?
is it really MV320????or a typo.
MV500s are CRT (heavy cathode RAY TUBES)
you model is rare now, no photos of it by you.so...
if not a CRT pig.
then it must be a flat screen monitor
the first ones, up to year 2010 used crapppy
CCFL back lamp tubes that are bad now. all are.
(unless never used)
call CCFL fail these ways.
dim.
white now yellow
dead.
blinks, or is intermittent,or strobes.l
the backlamps CCLF tubes are dead. all do that, or just die .
crt monitors
are junk and a fire hazard, trash it.
CRT fails more ways
sure dim,sure dead.
but it has 3 guns , RGB , red green blue.
the red gun loves to go weak first , red phosphors
are weak (a physics deal)
one trick (long long ago is to up the red gun levels, to compensate.
or lower Green/blue guns.
gun means "electron gun" deep inside the CRT neck
The CRT has even more bad effects, failed.
a huge endless list , if you want.we have it.
with photos
Jan 23, 2018 | Compaq MV 520 Monitor
Display (compaq 7500) is dead and there is a ticking sound from
Check the HOT also check to see if you have B+ voltage line looks like either fbt or output transistor.
Dec 27, 2009 | Compaq CV 7500 17" CRT Monitor
My compaq 5500 monitor is not changing its resolution
The video driver may have reverted to a standard VGA driver or your
video driver has stop working and needs reinstalling.
Sep 20, 2009 | HP Compaq MV 5500 15" CRT Monitor
I have Compaq MV 520 15 in CRT Conventional(India).....picture is redish in nature
the monitor is on its way out.
no fixes here. not worth the money.
you mention it is CRT. time to get a new one or go for LCD.
Oct 22, 2008 | Compaq MV 540 15" CRT Monitor
Compaq 1720 Monitor display comes on for 5 minutes and then goes off
change the main capacitor of power supply section .Hope this solution works.
Aug 01, 2008 | Compaq CV 7500 17" CRT Monitor
Display
Check Power supply(220/400v cap)
Mar 29, 2008 | Compaq 7500 17" CRT Monitor
Compaq 7540 colour looses red color
check the pin # 1 of video input cable { broken or Bent }
if it is ok then there must be a problem with the cable or RGB Processing Circuit { Normally Dry Soldering of a faulty IC in the circuit of CRT BASE} .
Mar 09, 2008 | Compaq CV 7500 17" CRT Monitor
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
