Question about Canon imageCLASS MF4320D
Paper jam error but remove all jam paper
I remove all jam paper and i clean all roller
  • Canon Expert
  • 1,326 Answers
You may need a new fuser unit....
Posted on Jul 16, 2013
SOURCE: Canon MX310 paper jam
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue.  I ended up finding an object lodged against the switch.  Needed a flashlight, plastic giftcard and a tweezers to get it out.  Works great now.
Posted on Jan 05, 2009
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
roit
  • 28 Answers
SOURCE: "Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Posted on Sep 04, 2009
FixinFax
  • 3085 Answers
SOURCE: Canon IR C3220 paper jam problem showing in the
Check to see if the EJECT SWITCH is hung up or out of it's holder.
Posted on Oct 30, 2009
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
HP 4215xi all in one, continues to give the error paper jam, there is no paper jam. I have cleaned all sensors, rollers etc. I have tried a partial and full reset. Any ideas?
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 2: Removing the rear access door
Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  1. From the rear access door opening, remove the jammed paper.
  2. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  3. Reinstall the rear access door.
  4. Reconnect the power cord to the unit and turn the unit on.
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Goodluck..
Mar 17, 2008 | Computers & Internet
HP c5180 printer paper jam error
Please try these general troubleshooting steps for paper jam issue: Turn off your printer to allow the paper feed rollers to turn freely. Remove the rear access door and check the pressure rollers. Verify that they are clean and clean the rollers with a soft towel if needed. Check if there is any jammed paper in this section and remove the jammed paper from the rear access door opening. Make sure that there are no torn pieces of paper in the fuser area and duplexer slot. Check if the carriage moves freely. Use both your hands to remove the paper that is stuck in the roller in order to avoid tearing of the sheet. Discard any paper that is damaged, and then reload the paper into the paper tray. Unlock the print cartridge access door. Check if there is any packaging material or paper debris stuck on the small metal pressure rollers that ride on the main feed roller. Do not mix different types of paper. Load only one type of paper for a print job. Make sure that the paper meets the paper-handling specifications. Slide the paper-length adjuster against the end of the paper stack and do not overfill the input tray. Connect the power cord and turn on your printer. Try to print a sample and if the error persists, then try to reset the printer. Try to update the driver. If nothing works, then service the printer.
123 HP COM Setup Printer Quick Setup and Install Support
Mar 24, 2013 | HP Photosmart C5180 All-In-One InkJet...
I have a HP LaserJet 1312nfi that is giving me a FALSE paper jam message. I repeat - FALSE PAPER JAM IN BACK DOOR. False false false. I have uninstalled it on my computer and nothing. I have opened it...
Hello Chris! Welcome to FixYa!
If you are facing False Paper Jam error in your HP Laser Jet 1312nfi but If you cant see any obvious paper jams, try to look closely into the rollers or the inside. There could be some tiny paper shreds stuck within those rollers. Or there could be a tiny piece of paper blocking the printer's sensor and thus giving you a false paper jam error.
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. Turn Off the printer and unplugged power before cleaning the rollers. This will allow the rollers to be turned by hand in most cases.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the back of the printer and check metal paper rollers (not the rubber rollers) in the interior of the printer. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the back cover and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
After following these steps carefully, False Error message will be disappeared.
I hope this solution helps you
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Jan 10, 2012 | HP Officejet Pro L7680 All-In-One Printer
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
How do you reset an H5-01 error code on Sharp Color MX2300 Copier.
Hello
Most error codes can be cleared by removing the paper jam and then rebooting the machine. When an error code occurs, make a note of the code and then follow the instructions on the control panel for clearing it.
Paper jams can be caused by a variety of issues in the copy machine, but jamming can commonly be caused by improperly loaded paper in the trays or dirty paper feed rollers.
If you get repeated paper jams, remove the paper from the trays and inspect the stack. Look for folded corners, especially on the bottom of the stack. Fan the paper thoroughly and then reload the stack into the tray. Check the paper guides to ensure they are not too tight or too loose. Both conditions can cause paper jams.
If you can see the paper transport rollers by opening the ordinary access covers and panels inside the machine, cleaning them might help reduce paper jams. Shut the machine off and unplug it, then take a soft, lint-free cloth dampened with water and wipe those rollers off. A buildup of toner and paper dust can cause them to slip while transporting the paper.
Oct 21, 2010 | Office Equipment & Supplies
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 14, 2010 | Canon SELPHY DS810 InkJet Photo Printer
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Canon imageCLASS MF4320D Logo
180 people viewed this question
old marine
old marine
