Setup unable format partition - Computers & Internet
    Brigadier General:
  • 3,400 Answers
EITHER IT IS A BROOKEN HARD-DRIVE
OR A BROOKEN DVD.
Posted on Jul 16, 2013
3 Suggested Answers
justsayes
  • 4 Answers
SOURCE: Unable to Format WesternDigital USB Hard Disk
Are you formatting a new disk or an existing one? Keep in mind that the rest of us do not know all the details that you know unless you tell us & thus it will take much longer to resolve your issue.
You said "after you tried it with XP CD". Dont know what you mean. What program did you use the first time & what steps did you do?
Posted on Nov 24, 2008
Sphynkter
  • 221 Answers
SOURCE: Please help me with my problem?
Toan96, I would recommend that you replace the drive. Why are you reformatting? Was it because there was a problem with the drive? This message you received indicates that there's a read/write problem with the disk.
Posted on May 18, 2009
"write protected" unable to format
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partition you want to format (where the leter and size is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select size, file format, disk letter, label etc should be all right if you leave defaults.
7. click ok
Dec 19, 2012 | Electronics - Others
How to install a new hard drive on computer using window xp
Step one is tosimply boot from the Windows installation CD and eventually the Windows XPSetup program will begin:clip_image002.jpgAfter acceptingthe EULA you'll be presented with a list of prior Windows installations:clip_image004.jpgWe want to installa fresh copy of Windows XP, so press the Escape key (ESC).The next screen showsus the available drives and partitions:clip_image006.jpgIn order to forcea reformat, we're going to delete the destination partition and recreate it.Click on the drivethat you want to install to, and press "D":clip_image008.jpgPress Enterto confirm that you want to delete the partition. Since this is a destructiveoperation (all information on the partition will be erased), Windows XP Setupasks again, just to be sure:clip_image010.jpgPress "L"to delete the partition.Now you've got anunpartitioned hard disk. Windows XP Setup now presents you with the list ofdrives and partitions again:clip_image012.jpgSelect theunpartitioned space, and type "C" to create a partition. You'll thenbe asked to enter the of the new partition:clip_image014.jpgThe default valueshould be the maximum appropriate for that partition, so simply press ENTERto continue.Setup returns youto the partition selection screen:clip_image016.jpgThis time what wasthe unpartitioned space is now "Partition1 [New (Raw)]". Select thatand press ENTER.Windows XP Setupnotices that your destination partition is not formatted:clip_image018.jpgThe default is toformat using NTFS, which is just fine for more situations. Press ENTERto let the format begin.Once theformatting is complete, Windows Setup then automatically begins copying filesto the newly formatted partition and continues with additional options andselections related to how you would like your new installation to beconfigured.
Jan 28, 2012 | Dell Computers & Internet
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
Mar 23, 2010 | Computers & Internet
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
Samsung40 gb harddisk unable to format (SP0411N). But i can read old data. I cant delete anything. cannot delete partition also
Try formatting / partitioning the drive with windows xp setup / installation cd. If you are trying to format or delete partition in windows and its your c: drive you will not be able to do that.
Jul 30, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Toshiba bios not starting
download partition manager it`s free
http://www.partition-tool.com/personal.htm
and you can format,create ,resize etc your partitions...
BACKUP ALL DATA BEFORE MESSING WITH PARTITIONS!!!
update bios first just make sure it`s right model number(read instructions)
Jun 15, 2009 | IBM ThinkPad T43 Notebook
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Computers & Internet Logo
David Payne
David Payne
