Goodmans DAB micro 1106 dab - Audio Players & Recorders
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
  • 395 Answers
SOURCE: Hi, Ive got a DAB digital
reboot it by taking all power away (unplug it if it uses batteries remove them) then return power.
Posted on Mar 08, 2008
SOURCE: how do i reset a
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Posted on Mar 10, 2008
welcomejee
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Lost instructions to my goodmans x pro GPS185DAB radio and I can't change the dab radio station- I am know stuck listening to absolute radio!!!
  • If you wish to download the manual, it is available at:
http://www.devicemanuals.com/support/goodmans-gps185dab-pdf-manual-68602.html
  • To scan for stations; press the Auto button. Press and hold for an international scan.
  • Once stations are stored, you use the UP and DN buttons to find the one you want then press Select
Hope this helps
Aug 30, 2012 | Audio Players & Recorders
Lost all DAB stations recently and purchased an
GOT NEW DAB MICRO IT KEEPS MAKING A RACKET BUT WHEN I TOUCH AREIAL WIRE I CAN GET STATION BACK WHAT IS THE PROB PLEASE HELP
Dec 18, 2009 | Audio Players & Recorders
No sound from Evoke-1 DAB radio.
I've seen a few (Pure & other brands) like this.No communications between the micro and the dab module . could be either thats at fault.. Doubt it would be an economic fix. sorry.
Nov 07, 2009 | Audio Players & Recorders
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Lodik dab 3006 radio
how to install a driver
Apr 30, 2008 | Computers & Internet
Buzzer instead of radio
I have this radio too and from what I have read in a review on amazon suggests alarm does not tune to DAB only FM - very annoying! Contacted Goodman customer care and they suggested it was a problem with a component but maybe it is just the design.
Mar 16, 2008 | Audio Players & Recorders
How do i reset a HITACHI AX-M131U DAB/FM/CD/USB/MP3 MICRO HI-FI SYSTEM i want to retune it
Mar 09, 2008 | Audio Players & Recorders
Faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Mar 06, 2008 | Televison & Video
53 people viewed this question
 Grubhead
Grubhead
