Question about Radio Communications
I have a connex 4600 turbo and wanted to know what is the best external speaker i could get for this high power radio. Thanks Shawn
  • 16,984 Answers
Are talking PA or inside speaker?
Posted on Jul 18, 2013
Benimur
  • 6966 Answers
SOURCE: Connex 4600 turbo export radio
On most mobile communications equipment, it is best that:
1. the power leads are directly wired to the battery terminals;
2. the bracket and radio body are grounded to the chassis of the vehicle;
3. a braided grounding strip be used in addition to the negative power lead; and/or
4. a gutter or trunk lip mounted antenna be used rather than magnetic. Antennas are better made of metal rod (not fiberglass) such as those made by Daiwa, Maldol, Oscar, Hokushin and others. The mount itself should use high quality RG58 coaxial cable such as those by Belden and others.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 31, 2007
bunnydawg
  • 5158 Answers
SOURCE: owners manual for connex 4600 turbo
to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
Robert
Please rate this solution thanks
Posted on Feb 23, 2009
SOURCE: Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Posted on Mar 28, 2009
Mister 44
  • 35 Answers
SOURCE: connex 4600 turbo radio stays keyed up even with
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Posted on Apr 03, 2010
anymhz
  • 500 Answers
SOURCE: I have a connex 4600 turbo very good radio!! But
check for any loose power connections.. ground connections.. loose coax.. also make sure vehicle is on so not to drain battery down when TXing. if it was off it may have dropped battery voltage down lower than it should... and turned off.. RX doesn't use hardly any ampres..
Posted on Mar 29, 2011
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
I would say yes it has a large heatsink. The variable might be the tuning. But if it's amp is not being pushed any harder than factory you will be fine. Nice radio I prefer them over the 4400turbo and the 3600hp it has the board like a 4300 not the 3300s like the fore mentioned.
May 26, 2014 | Connex 4600 Base CB Radio
What is the best power mic for the ranger vr 9000
Astaic 36L. You never want to run a power Mike with a good radio with Mic Gain. Road King is great to. It is very hard to find the honey spot with a power Mike when you have Mike gain on radio.I think it is pretty hard to beat the 36L. I use one one my Connex 4600 Turbo and Galaxy 95T2, They both performe great. Connex is a little better a DX ing though
Nov 22, 2013 | Ranger VR-9000 Base CB Radio
I have a connex 4600 turbo with a road king 56 noise canceling mic. My mic just started making a cracklin sound in my external speaker . It also shocks and burns me. When I key up and let go it stays keyed...
Sounds to me like the RF signal is leaking into the microphone. Check the cable to the microphone and see if the ground wire is bad. Check the SWR to see if it is high. The problem you are talking about is unusual.
Jun 28, 2013 | Radio Communications
Connex 4600 turbo. Poor receive. About 4 mi.
Hi there!!
The Connex 4600 Turbo is a very sensitive radio these radios don't work good at all with the stock microphone! The best microphones are the RK-56 and or the Astatic 636L which most people use and you shouldn't get any squeal. And make sure if that you are using an external speaker get it as far away from the radio as you can facing away from the radio so it wont feedback. As far as a Mod kit there are several ways to modify the radio which most are pretty hard and drawn out. but the most easy that used to be used is as simple as a diode placement in the right place which is old school but still works good. You must be very careful as if you are to slightly touch the wrong points the radio could be destroyed and no longer work so caution is to be taken if you don't know what you are doing please don't try it on an expensive radio!! If you want more info on the mod e-mail me
never the less a Modulation kit or modification wont help your Receive it will only help your Transmit signal!!
Dennis
May 20, 2009 | Connex 4600 Base CB Radio
Owners manual for connex 4600 turbo
Robert
Feb 23, 2009 | Connex 4600 Base CB Radio
Connex 4600 Turbo
Feb 10, 2009 | Connex 4600 Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Dec 31, 2007 | Magnum 257 CB Radio
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
