Question about Malber WD1000 Front Load Washer/Dryer
Clothes are still sopping wet when finished
Does anyone know where to get parts for the wd1000 malber....i have never used it as a the dryer only becaue when i got it off of a friend it wasn't working then. So it probably could use a heating element as well as a pump...if that is what the no draining/sopping wet clothes problem is. If anyone has any advise , it would be much appreciated. Nefertiti PS I did find a malber website, which was no help
  • gmretrey Nov 28, 2007
    • I have the same machine and the problem has been intermittent for seven years. I've discovered that it's an issue of the amount of clothing placed in the drum. The more, the better. Any time I did half a load or less, the spin cycle did not work properly. Fill the machine to 3/4 capacity, minimally, and it should spin dry. When I called Malber, they said it had to do with balancing the clothes.
  • Anonymous Nov 09, 2008
    i have same problem wet clothes when machine finished but also my washing is covered in grey grittty stuff, my machine is a indesit without a filter
    President:
  • 1,294 Answers
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Posted on Sep 01, 2007
SOURCE:
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
I just got a malber 1000 washer/dryer. Can it be used as a dryer only?
NO THIS UNIT USES CONDENSED DRYING AND WILL WET THE CLOTHES BEFORE IT EVEN TURNS ON THE HEATER. BASICALLY YOUR COMBO USES STEAM CIRCULATION THRU YOUR CLOTHES. AS THE SMALL WATER PARTICLES IN THE STEAM MOVE THRU YOUR CLOTHES IT COMBINES WITH SMALL WATER PARTICALS IN THE CLOTHES(THINK OF 2 WATER DROPS COMBINING ON YOUR WINDSHEILD AND HOW THEY ABSORB TOGETHER) WHICH RISE TO THE TOP OF THE TUB AND COLLECT INTO WATER AGAIN. THEY THEN ROLL DOWN THE SIDES OF THE TUB AND COLLECT AGAIN AT THE BOTTOM TO BE PUMPED OUT. BEFORE THIS PROCESS EVEN STARTS THE UNIT WILL ACTUALLY ADD WATER TO GENERATE THE STEAM. MOST PEOPLE FIND THAT IF THEY WANT TO JUST FRESHEN UP SOMETHING, IT WILL END UP DRENCHING WET IN THE FIRST FEW MINUTES.
Jan 18, 2010 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Heats but won't dry
I'm not at all familiar with the Malber brand, but I do know that the basics any dryer needs to work are: 1. Heat 2. tumbling (so the air can reach all areas of the wet clothes) and 3. air flow, so the moist air is removed from the dryer.
The number one cause of poor or no drying is poor air flow. Check the end of the vent outside to see if you are getting a strong flow of air out when the dryer is running. I'll bet you are not. Find out why and correct. (clean out lint, reduce or better yet eliminate any flex duct, try to make vent pipe as short and straight as possible, use a dryer vent end cap which has a large opening, etc.)
Nov 02, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer won't dry
www.malberusa.com
61 Commercial Ave
Garden City, NY 11530
(516) 294-6660
first empty the waste container on the right buttom of your machine you have to empty that container every couple of washes.if not solved replace the heating element. the tel # above.
good luck
Hadi
Sep 24, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber wd1000
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
Apr 22, 2008 | Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
check two places. repair clinic dot com and parts select dot com
Sep 06, 2007 | Malber WD1000 Front Load Washer/Dryer
Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
Jun 26, 2007 | Malber WD1000 Front Load Washer/Dryer
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company ([email protected])
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
509 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Android Man
Android Man
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
